battery
Aug 26, 2015 | 06:30 AM
battery
2003 coupe
is changing the battery just take old out and new in,or are there things to do first to avoid problems.
thanks for any input.
Aug 26, 2015 | 07:05 AM
Nothing special at all. Safety says just remove the negative cable first.
Aug 26, 2015 | 07:18 AM
what brands are best for the c5.
buying a 03. 6 year old battery and don't want the cl problem.
thanks
Aug 26, 2015 | 07:56 AM
Quote:
Originally Posted by
firstvette99
thanks
Take a look at the Sears Diehard AGM batteries.
Aug 26, 2015 | 08:49 AM
Aug 26, 2015 | 08:22 PM
runner140*
I bought a Sears DieHard Platinum battery nearly five years ago - not a single problem with it.
Aug 26, 2015 | 09:51 PM
St. Jude Donor '13-'14-'15
Just remember this----- when dis connecting the battery or changing it---The ECM loses all the Data it has learned about fuel trims and has to "re-learn" the trims all over again--The more modded your car the longer it takes---On a basically STOCK engine the re-learning should take about 50-75 miles of normal driving in order for the ECM to learn out-------While it is the learning mode--chances are the engine will not run at it's fullest potential--this is simply the nature of a computer controlled fuel injected modern engine
Aug 27, 2015 | 12:12 AM
runner140*
Sears Die-Hard Platinum Group 34/78 Dual terminal
Look for "Platinum" wording in description.
PS, when disconnecting/connecting cables you may hear some "clicking" noises. Perfectly normal. (Relays)
Aug 27, 2015 | 12:18 AM
LoneStarFRC
I thought the clicking noise were the tabs on the beer cans getting opened... oh well.
Aug 27, 2015 | 12:47 AM
73Corvette
Only when RE-connecting............
