ASP Pulley + RollerMaster Chain = NO GO!!
Old Aug 22, 2002 | 10:27 AM
Jason 98 TA's Avatar
Jason 98 TA
Premium Supporting Vendor
Default ASP Pulley + RollerMaster Chain = NO GO!!
For anyone who was going to run a RollerMaster double chain on with a ASP pulley get ready for some machine work :( :( The ASP pulley won't clear the oil pump after you install the 3mm spacers required with the timing chain kit! After we installed the asp pulley the new motor was completely locked down :( :( We ended up pulling the pulley back off & now I have to get it machined down at Sunset Racecraft. So maybe the C5R chain is still the best option!??>!?!
Jason
1999 FRC
JPE Racing Stage 2+
Heads & Cam
LQ9 Speedaholic Heads
JPE Racing FU-2 Cam
www.jperacing.com
Old Aug 22, 2002 | 10:33 AM
Bill Reid's Avatar
Bill Reid
Default Re: ASP Pulley + RollerMaster Chain = NO GO!! (Jason 98 TA)
Jason, Thanks for the heads up... are you going to contact ASP and let them know? Seems this may interest them considering many opt for ASP when "already in there" upgrading heads and/or cam...
:cheers:
Old Aug 22, 2002 | 11:32 AM
Patches's Avatar
Patches
What machining exactly needs to be done to get the pulley to clear? I was thinking of going with this setup and would like to get the machine work done ahead of time.
Thanks for the heads-up! :cheers:
Old Aug 22, 2002 | 12:59 PM
Miles in Michigan's Avatar
Miles in Michigan
Damn. I have an ASP pulley sitting at home, and a rollmaster dual chain on it's way from Austrailia!
What exactly need to be machined? The pulley itself? Is it because the diameter is too large, or because the pulley is too thick (extending towards the back of the car)? I can't really picture what the problem is.
Old Aug 22, 2002 | 01:17 PM
Jason 98 TA
Ok everyone brace yourself for these lame attempts at showing what I'm talking about.
asp pulley shape
-------------\___
________/-----
The point where the asp pulley gets wider for the seal is where you need to machine. Make it look like this
-----\________
___/-------------
Just move the point that it bottle necks down close to the pulley so the oil pump has the additional 3mm it needs :) :)
Jason
Old Aug 22, 2002 | 01:47 PM
Patches's Avatar
Patches
Close enough, man! Thanks! :cheers:
I'll measure it up and do a CAD drawing to give the shop when I have mine done. :yesnod:
Old Aug 22, 2002 | 01:57 PM
C5Noir's Avatar
C5Noir
Default Re: ASP Pulley + RollerMaster Chain = NO GO!! (Patches)
Ed, you rock man! I wish I had your CAD skills ;) (Hell I wish I had ANY CAD skills :D)
Old Aug 22, 2002 | 02:06 PM
Patches's Avatar
Patches
Default Re: ASP Pulley + RollerMaster Chain = NO GO!! (C5Noir)
Heck, Levi. You ever need something, just let me know and I'll get you fixed up. :cheers:
Old Aug 22, 2002 | 03:29 PM
Jason 98 TA
You wont need any cadd pics, just look at where the pulley goes into the seal & you'll understand what I'm talking about :) Its really obvious when you have it all infront of you, its just hard to describe :(
Jason
Old Aug 22, 2002 | 03:42 PM
Patches's Avatar
Patches
Don't spoil my fun! :D
It'd be good to document it for others anyway. :yesnod: :cheers:
:seeya
Old Aug 22, 2002 | 04:05 PM
NJVetteGuy's Avatar
NJVetteGuy
Could you post in in .dwg or .dxf format for the rest of us to d/l after ya finish? Thanx!
Old Aug 22, 2002 | 05:05 PM
Patches's Avatar
Patches
Default Re: ASP Pulley + RollerMaster Chain = NO GO!! (NJVetteGuy)
Sure will. :yesnod:
Old Aug 22, 2002 | 09:43 PM
Patches's Avatar
Patches
Jason, to be sure before I go any further, which one of these surfaces needs to have it's depth reduced 3mm? (Surface A or B)
[Modified by Patches, 8:49 PM 8/22/2002]
Old Aug 22, 2002 | 10:40 PM
gojo's Avatar
gojo
Sorry you had the problem, but glad your sharing the info.
I've never worked on a c5 engine, so I don't know exactly where the oil pump will make contact. I'm sure a lot of us could use help on this. Here's a link showing installed pump that might help us understand where it rubs.
http://ls1.fbody.com/car/mods/oilpump/install.html
[Modified by jfpilla, 11:05 PM 8/22/2002]
Old Aug 23, 2002 | 08:31 AM
Patches's Avatar
Patches
Default Re: ASP Pulley + RollerMaster Chain = NO GO!! (jfpilla)
ttt :cheers:
Old Aug 23, 2002 | 09:22 AM
C5 Tweaker's Avatar
C5 Tweaker
No problem with my installation.
I have had the RollMaster (Nice!) with an ASP pulley for several months with no issues. I just replaced the pulley last night (unrelated - the pulley failed - steel ring slipping on aluminum hub) but there was NO sign of an interference problem.
As part of my initial pulley failure investigation, I measured the insertion depth compared to stock and it was within ~.5mm.
I am not sure how to account for the differences in out observations.
Is the sealing surface contacting the pump body, or is the back of the pulley contacting the pump rotor? What is the distance from the end of the crankshaft to the bolt contact surface of the pulley?
[Modified by C5 Tweaker, 7:42 AM 8/23/2002]
Old Aug 23, 2002 | 09:46 AM
Patches's Avatar
Patches
Default Re: ASP Pulley + RollerMaster Chain = NO GO!! (C5 Tweaker)
Sounds like there was an installation discrepancy in one of the steups here. :confused:
C5 Tweaker - Thanks for your input. I may just key the pulley before it goes on and hold off on the machining until an initial fitting is done at install.
To ASP Pulley + RollerMaster Chain = NO GO!!
Old Aug 23, 2002 | 10:33 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Ahh yet another reason to stick with the stock pully. :yesnod:
Old Aug 23, 2002 | 01:28 PM
gojo's Avatar
gojo
Default Re: ASP Pulley + RollerMaster Chain = NO GO!! (Godspeed)
Godspeed, you of all people should know better. If the challenges faced by mods stopped us we wouldn't do any. Get my drift.This is meant to be slightly light hearted.
Old Aug 23, 2002 | 01:39 PM
Patches's Avatar
Patches
Hear, hear!
:cheers: :D :p: :jester :seeya
