Crank and Cam sensor plugs?
Old Sep 2, 2015 | 04:47 PM
rttmike's Avatar
rttmike
Default Crank and Cam sensor plugs?
Bought a timing twister to pull timing. It says I need to plug into the Crank and Cam sensors for signal. Where do I located these? Do I need to remove the headers and starter to access these?
Old Sep 3, 2015 | 12:12 AM
zachaeous's Avatar
zachaeous
Default sensors
The camshaft sensor is located behind the intake manifold on the back of the block. and the crankshaft sensor on the LS1 is located on the right hand side of the engine block behind the starter. You have to remove the starter so if your headers are in the way yes. To get to the camshaft sensor you would have to remove the intake manifold
