and another Spark Plug thread.
What do you guys think?
At 62K miles, I would definitely change both sparkplugs and wires.
Sparkplugs, wires, O2 sensors, MAF sensors, shocks are types of components that degrade so slowly that you don't notice how bad they really are until you replace them and are amazed at the improvement.
100% Just ordered a set of GMPP Red Spark Plug Wires and AC Delco Iridium Spark Plugs #41-110
At my skill level, if it aint broke don't fix it , carries a lot of weight. A whole lot o' weight. Plus, my enthusiasm for car work is apparently less than most here.
I also agree that electrical stuff can degrade over time. I saw this demonstrated on HotRod TV with a C5 hooked up to a display showing the tighter waveforms of new coils over the old. However, the electrical requirements to meet specs were not discussed, and I have plenty of old electronic stuff that works great. I do plan on looking into the health of my coils, only because of a very slight off note at idle, it is so subtle it might just be characteristic of the design, it doesn't effect my performance needs at all, and is only heard at idle.
That being said, you already have good functional plugs selected for long life over performance. By that I mean effective spark is not a problem with this design, so much so that spark plugs were selected with durability as the main criteria for fitment in this performance car. Copper conducts better than iridium, but doesn't last as long , and some of the die hards put copper plugs in because of this fact about conductivity, and call it an upgrade. With the dealer service price of a plug change in mind, the more durable plug offers more happy customer benefits and no performance downside in this system .
I changed my plugs and wires when I attacked my oil pressure sending unit, using the same stuff on your car now. Mine is a 2003, and benefitted from a revised GM spec, a slightly tighter spark gap , smoothing the idle a bit. I changed because of some milage considerations, but mainly because I bought the car used, and wanted a clean understanding of what I was working on.
I wouldn't mess with the plugs unless you have performance issues or are near the projected end of life. In the old days, with dirty combustion, plugs had a much harder life, and were often featured in ads from parts stores, much as oil is today. Now, the demand has changed, as evidenced by the parts ads that respond to the market place. PLugs are no longer an important performance weak spot , I would save the money and time for other agendas.
I once had a low mileage 4 year old 2g Eclipse Turbo that started misfiring badly out of nowhere. One of the spark plug wires insulation had melted through.
The GMPP wires are like $60-70. Cheap insurance.
Quote:
Sam, like many things I find on the Corvette Forum.. too much thought goes in to the finite discussion on things like spark plug gap. Back in the 60 and 70's spark plug gap was much more critical because of the ignition system.
Todays Plugs are designed with much better materials and design. Reach and heat range are dialed in at the manufacturing process. These plugs are designed to go 100,000 miles. Ive seen factory plugs at 100,000 miles with the gap at 0.070 in. without issue. 40 years ago a couple f thousandths could effect performance in a negative way. But Not today. The controversial range in plug gap from 0.040 to 0.060 is the range the plug could see during its life time. I tell people all the time to gap at 0.050 and they can successfully operate within the design even at 0.060. This overthinking is a waste of thought process. I understand everyone want the best. But the plug will properly deliver an Ideal spark and a much wider range than a single gap number.
I hope this helps . there are much bigger fish to fry then debating plug gap. Over kill ( or over thinking ) is a waste of time and money in this case.
There is no concern in a normal wear scenario over the life of the plug. Think of it this way.. if plug gap was critical, the manufacturer would have you chance the plug when the plug gap changed over normal use. Plugs can be successfully use for 100K, GM did testing to insure this when they were testing for 200,000 mile benchmark compliance. That's why Plug scheduled maintenance was set at 100K in the owners manual. IN 100K the plug gap does change, with little to no effect in performance.
Not sure if this helps, but that my thoughts. Bottom line.. too much sweat over a very small issue.
