dWhat is the normal current draw from the battery with the engine off?
Old Aug 22, 2002 | 04:08 PM
RennfahrerX's Avatar
RennfahrerX
Default dWhat is the normal current draw from the battery with the engine off?
My car has recently started to display the "low voltage" message on the DIC. The voltage shows 13.8 V with the engine running so I believe the alternator is functioning properly. I'm going to have the battery checked although the car only has 7500 miles. I'm wondering what is the typical current draw with the engine off and does anyone have any suggestions as to the culprit responsible for a higher than normal current draw (assuming that my battery checks out OK)?
Old Aug 22, 2002 | 06:49 PM
NJVetteGuy's Avatar
NJVetteGuy
Default Re: dWhat is the normal current draw from the battery with the engine off? (RennfahrerX)
Check for a loose battery connection first, and inspect the grounds. The current draw should be less than 700 mA, but it will need to be checked with an inductive pickup so the cap in the light module charging up doesn't throw your reading off while you're hooked up in series. My '01 had a loose battery cable right from the factory, so anything is possible. I'd say it's a good chance that either your battery or the connections are the culprit though. Email me if you need any more info. :cheers:
Old Aug 23, 2002 | 12:47 PM
BigBlue's Avatar
BigBlue
Default Re: dWhat is the normal current draw from the battery with the engine off? (NJVetteGuy)
Our dealer told us that if we plan on letting the car sit for more than about 3 days, we need someone to drive it around to charge it. All of the electronic gizmos and gadgets drain a lot.
Old Aug 23, 2002 | 01:14 PM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
Default Re: dWhat is the normal current draw from the battery with the engine off? (BigBlue)
My battery will not crank the car if it sits for 3 weeks. Been that way since I bought it. I just put a charger on it if it sits for a while. Better to use a charger than let the alternator charge the battery back up to full charge. :seeya
Old Aug 23, 2002 | 01:15 PM
jerryv's Avatar
jerryv
Doesn't sound right to me .. mine's sat for at least 10 days without any problems. Once you've shut the car down, it basically goes to sleep until something 'wakes it up' .. like opening a door or trunk lid, using the key fob, etc. There have been a lot of battery problems reported on C5s.
Old Aug 23, 2002 | 02:08 PM
Richin Chicago's Avatar
Richin Chicago
WOW! Mine sat for 6 weeks last Winter and it started fine.
Old Aug 23, 2002 | 02:31 PM
55SUX's Avatar
55SUX
Normal current draw with everything turned off is about 25-27 mA. It takes a little bit of time for everything to power down. 700 mA stated above is way too high and not normal. Unfortunantely when you disconnect the battery to hook up the ammeter in series everything resets and has to power down. That's why GM makes a special switch so that the power isn't interuppted when connecting the ammeter. You can do the same thing with one of those battery quick disconnect swiches they sell. Make sure you disconnnect the under hood light and everything else is turned off. When you connect up the ammeter you will see a draw at first of about 1.3 A. Then about 800-900 mA, then about 90 mA, then about 34 mA, then finally about 27 mA when everything turns off.
It's probably the battery. Don't be surprised if they tell you the battery is ok. I had mine checked and they said the battery was ok. Still had problems. Did exhaustive checks looking for excessive current drains and couldn't find any. Replaced battery. Everything is fine.
[Modified by 55SUX, 12:42 PM 8/23/2002]
Old Aug 23, 2002 | 02:35 PM
Tom/99's Avatar
Tom/99
My 99 Coupe has sat in the garage for two weeks, while I was out of town. I had no problems starting it when I got back.
Old Aug 23, 2002 | 10:07 PM
fdxpilot's Avatar
fdxpilot
I'm frequently out of town for more than a week at a time, and my 4 month old coupe cranks up every time I get back and hop in. My airport car (94 Z) is much more likely to have a problem with it's 4 yr old Diehard.
To dWhat is the normal current draw from the battery with the engine off?
