C5 Check Engine Light...
Old Sep 6, 2015 | 09:30 AM
DarthSimon's Avatar
DarthSimon
Default C5 Check Engine Light...
Good Morning Guys,
Check Engine Light came on today, pulled codes....
Thoughts?
10 PCM P0753
60 IPC u1160
AO ldcm B2262
BO RFA:
u1096
U 1064
U 1016
C2120
Thoughts?
Steve
Old Sep 6, 2015 | 09:39 AM
dadaroo's Avatar
dadaroo
I will look but not knowing how long these have been the I need you to delete them and them pull them again when you get another CEL.
Also, always tell us what year your car is as a minimum.
Mr. Sam
Old Sep 6, 2015 | 09:40 AM
DarthSimon's Avatar
DarthSimon
Sorry, Its a 2000, I will go clear codes and take a drive and report back...
Old Sep 6, 2015 | 09:52 AM
DarthSimon's Avatar
DarthSimon
Cleared codes, CE light went off, I will drive car in a bit and see if it comes back on.
Old Sep 6, 2015 | 09:57 AM
dadaroo's Avatar
dadaroo
Quick look tells me that P0753 is probably the issue. It will set the CEL.
Here is a link to explain it and the diagnostics.
https://www.dropbox.com/s/vctadocue9...P0753.pdf?dl=0
Mr. Sam
Old Sep 6, 2015 | 10:21 AM
DarthSimon's Avatar
DarthSimon
Light not coming back on, after 5-6 miles... Will run codes when I get home...
Old Sep 6, 2015 | 10:41 AM
73Corvette's Avatar
73Corvette
Pull them before you KILL the car like I said in your other thread...
Old Sep 6, 2015 | 10:46 AM
DarthSimon's Avatar
DarthSimon
After 10 miles of driving, pulled codes again, nothing. Should I worry about this?
Old Sep 6, 2015 | 11:29 AM
73Corvette's Avatar
73Corvette
NO... make sure your battery is fully charged, drive and enjoy it.
You can make yourself sick worrying about all the things that could go wrong with these cars...it's kinda like quail hunting... don't shoot at the whole covey... just pick one bird when it get's up and KILL it. lol
I have found there are plenty of other things to worry about in this life... she'll let you know (usually) if there is a problem.
Old Sep 6, 2015 | 11:55 AM
DarthSimon's Avatar
DarthSimon
Thanks Guys....
Old Sep 6, 2015 | 10:47 PM
DarthSimon's Avatar
DarthSimon
Took car for another long drive tonight... No more codes... Nor CEL...
Old Sep 7, 2015 | 06:47 AM
dadaroo's Avatar
dadaroo
That's good, like the other guys said, I would not worry. Many of the modules will have a hiccup in reporting status. Even Dave Hill the C5 Chief Engineer said they had many such issues occur through the life of the C5. Not unlike your home computer.
Mr. Sam
To C5 Check Engine Light...
