2003 C5 running hot at idle
Old Sep 7, 2015 | 10:41 PM
wjacobs82's Avatar
wjacobs82
Default 2003 C5 running hot at idle
Hello, I'm looking for information on what could be causing my car to run a bit hot at idle or slow speeds. Its hoovers around 240 temp but only does it at idle. When I'm driving at speed it's around 218, slightly under the middle mark on the temp gauge. As far as I can tell both fans are running and the coolant is a greenish yellow color. Im not seeing the the index marks that the manual says to use to check the coolant level, so I'm not sure if it's low or not. Any suggestions or info would be appreciated. Thanks
Old Sep 7, 2015 | 11:15 PM
corvette77's Avatar
corvette77
Have you looked to see if any trash has been sucked up into the radiator? I would also suggest blowing the radiator out, to make sure it isn't plugged up with dirt and other stuff.
Old Sep 7, 2015 | 11:21 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
well if you have done nothing to the car recently I would check the radiator for debris you will most likely have to get under there to really look....a plastic bag perhaps....dirt and grass ain't enough by itself.
any signs of leaking from the water pump? maybe the impeller is crap and not moving water as effectively as it should....
only time both fans run is if the AC is on or you reach 226 (I think)
I'm sure 8vette7 will be along shortly with his excellent primer on this issue
Old Sep 7, 2015 | 11:42 PM
wjacobs82's Avatar
wjacobs82
Yes I've got under the car and cleaned the radiator with soap and water, gave it a gentle scrub and sprayed it out. As for the water pump, I haven't noticed anything leaking but will take a look at it.
Old Sep 7, 2015 | 11:46 PM
wjacobs82's Avatar
wjacobs82
In regard to the fans, I let the car warm up in the driveway withe the a/c off. When I first cranked it there was only one fan on but when the temp reached around 220 the second fan would turn on, run for a bit, then turn off. It would repeat this process while the car was running at temp. I would assume that the fan is operating correctly doing this?
Old Sep 7, 2015 | 11:49 PM
wjacobs82's Avatar
wjacobs82
when you say blow the radiator out, do you mean using a air compressor with a air nozzle?
Old Sep 8, 2015 | 12:29 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Yes, from the back (fan side) toward the front. You can also try a garden hose at normal household pressure (but don't use a pressure washer). Let us know your results !
Old Sep 8, 2015 | 12:32 AM
wjacobs82's Avatar
wjacobs82
OK thanks, I've been spraying from the front towards the engine. I'll give it a try
Old Sep 8, 2015 | 04:22 AM
StingrayRebel's Avatar
StingrayRebel
dexcool is an orange/pink color, you sure you have the right stuff in there?... if it's regular antifreeze I would get that flushed out asap... the coolant level mark is on the surge tank and reads "full cold"
Old Sep 8, 2015 | 08:03 AM
65GGvert's Avatar
65GGvert
Both fans should run on low speed, and both speeds should run on high speed. They don't ever run only one at a time. The temp these fans run low and high is set by the tune. If you're stock, both fans should run on high when temp reaches about 236 degrees and switch back to low when it reaches around 219. You may have one of the 30 amp fuses in the under hood fuse box blown. The fact that it cools down at speed tells you that the radiator is reasonably clear. The fans turn off at 35 mph and don't help cool. I'd look seriously at the fuses and/or relays that run the fans.
Old Sep 8, 2015 | 02:26 PM
wjacobs82's Avatar
wjacobs82
Thanks for the info, that helps alot. The problem definitely seems to be the fan or an electrical issue associated with it. I'll check the fuses but probably will have to take it to someone for the relay troubleshooting
Old Sep 8, 2015 | 02:28 PM
wjacobs82's Avatar
wjacobs82
I'll have to check it again... got it from a chevy dealership so I would assume that they checked the coolant to make sure it was right.
Old Sep 8, 2015 | 03:06 PM
pjensen's Avatar
pjensen
How many miles on the car?
I just replaced my water pump, hoses and radiator at 130,000 miles. The coolant temp is 200 or less while driving (outside temp at 100 dF). While idling it might reach 205.
Before I did this, it was between 225 and 235. I tried cleaning the old radiator and that helped a little.
I bought a exact gm radiator for $205. Totally fixed it.
Also be sure when you refill the coolant, that you burp the engine. This is a procedure to get the air out of the cooling system. It works.
Old Sep 8, 2015 | 03:08 PM
wjacobs82's Avatar
wjacobs82
37000 on my car
Old Sep 8, 2015 | 05:04 PM
pjensen's Avatar
pjensen
37000 on my car
Get under the car and check for leaks. Use a good flash light and have a good look around.
On a 12 year old car, I would look carefully around the radiator hoses and water pump area. The overflow reservoir has a real thin plastic pipe (that connects to a small radiator hose) - that likes to crack. If there is any leak at all, the coolant will not get pressurized. I had to replace that reservoir also.
I tried to replace the hose clamps with some stainless steel type (with a screw). Those did not work at all. Ended up going back to the gm clamps I had.
Most of these parts are pretty cheap (in vette terms). Just get the exact gm replacement. The original stuff lasted 10 years - good enough for me...
Old Sep 8, 2015 | 05:27 PM
73Corvette's Avatar
73Corvette
HOW did you get under the car and clean the Radiator?
The A/C Condenser sits in front of the radiator...unless you took the A/C Condenser OUT there is only about 3/4 of an inch between the A/C Condenser and the Radiator... I don't know how you would wash it.
The BEST method to REALLY clean your Radiator is to TAKE IT OUT...
Old Sep 8, 2015 | 05:44 PM
pjensen's Avatar
pjensen
I have Kwik Lift - the car is 30" off the floor.
Easy to get under and blow out the dirt with a air compressor and wand. I take the top radiator holder off (4 bolts) and separate the a/c condenser and disconnect the fan. It is a pain but doable...
To 2003 C5 running hot at idle
Old Sep 8, 2015 | 06:02 PM
73Corvette's Avatar
73Corvette
Gotch ya... that should work fine
Old Sep 8, 2015 | 06:18 PM
Big_George_S's Avatar
Big_George_S
Do a search here on overheating you will find good information on how to clean your radiator, the correct fluid, and other good suggestions on how to keep your cool.
It is also a good forum practice to post specifics about your car, i.e. is it modified with any power upgrades, exhaust, etc. This information helps folks respond to your question. My '04 is highly modified so I've done several upgrades to help keep it cool. If your's is not follow the advice that has been recommended. Clean out the radiator; change the fluid to the correct antifreeze; verify your thermostat is opening correctly; do a visual inspection for leaks; and make sure that you have cleared the air out of the system (burped it).
I've just changed out my radiator due to leaks, the OAT's have been around 90 to 100 and my temps run around 195 to 205. That being said I have a highly modified cooling system so I tend to run on the cooler side on the street so that I can hold temp on the track.
Welcome to the forum and always check here before you go to the dealer.
Old Sep 8, 2015 | 08:13 PM
65GGvert's Avatar
65GGvert
I mentioned the 30 amp fuse because I had the same issue on a used 2004 I bought last year. Before I left the lot, their mechanic checked it out and one of the large green 30a fuses was blown. He changed it and I had no more trouble with the fans. My recollection is that there are 3 of them, but they're easy to measure.
