Clunking Sound
Old Sep 10, 2015 | 04:49 PM
topfuelr's Avatar
topfuelr
7th Gear
Default Clunking Sound
I have a 2003 c5 with 28000 mi, when I make a left u turn there is a clunking sound in the front end?
Old Sep 10, 2015 | 09:21 PM
corvette77's Avatar
corvette77
Sounds like a bearing hub to me. Jack the front and see if there is any play in the wheels, when pulling at the 12 & 6 o'clock positions. If those a tight, check the sway bars.
Old Sep 25, 2016 | 08:20 PM
topfuelr's Avatar
topfuelr
7th Gear
Default Center Console
I have a 2003 corvette and the center armrest conpartment runs very warm, any ideas?
Old Sep 25, 2016 | 11:13 PM
momo20's Avatar
momo20
let's focus on one issue at a time...
Old Sep 25, 2016 | 11:43 PM
CactusCat's Avatar
CactusCat
Since you only hear the clunking noise on left u turns, check your end links on the sway bar, check the sway bar to make sure its tight as well. If you need to replace the end links (they do go bad), make sure to get the metal ones. Other areas is a general inspection of the entire front suspension making sure you don't have any loose bolts. Keep us updated as to what you find.
Old Oct 29, 2016 | 11:08 PM
topfuelr's Avatar
topfuelr
7th Gear
Default Security Dash Light Stays On
My Security Dash Light Stays On, I have replaced the ignition switch, cleaned the pearl on my key and it still stays on?
Old Oct 30, 2016 | 04:05 PM
jrprich's Avatar
jrprich
This is unfortunately normal to all C5s
You can pull the console and use some thin reflective heat insulation on the trans tunnel top. Then reinstall the console. This will help, but not entirely resolve the heat issue. I have used FrostKing self-adhesive duct insulation in the past with fair results. On my recent 03 I used a product that is foil faced on both sides with a center of small plastic bubbles. No adhesive but seems to reduce the heat as well as the FrostKing stuff....
Old Nov 4, 2016 | 10:27 AM
huesmann's Avatar
huesmann
Sounds like you need to pull your DIC codes.
To Clunking Sound
