LS1 Long tube headers on LS3 engine?
Old Sep 12, 2015 | 05:00 AM
VinnyVette's Avatar
VinnyVette
Default LS1 Long tube headers on LS3 engine?
Would LS1 LT fit on LS3 heads?
Old Sep 12, 2015 | 05:34 AM
7LitreC5's Avatar
7LitreC5
They will bolt up without problems and fit perfectly. I had a LS3 headed engine in my C5 at one point and used my LS1 headers.
Old Sep 12, 2015 | 08:05 PM
VinnyVette's Avatar
VinnyVette
Can the stock C5 trans , half shafts, and diff handle around 500 wheel torque? I already have fairly new LS7 clutch in as well. That's my optimistic goal after long tubes, cold air, and pump gas dyno tune with the LS376/480 crate engine. Is there anything I should replace when doing the engine swap?
Old Sep 12, 2015 | 08:24 PM
7LitreC5's Avatar
7LitreC5
It should be fine. My car only has a hardened driver's side diff output shaft. The half shafts and trans in my car are still stock. I've run the current LS7 and in the past heads/cam/headers/sc and never has a problem with anything.
Old Sep 12, 2015 | 09:51 PM
Last C5's Avatar
Last C5
My C5Z has an LS7 in it that puts out 565 to the wheels and it has stock diff, half shafts, and torque tube. It sees the track regularly in this configuration.
Old Sep 13, 2015 | 03:25 AM
VinnyVette's Avatar
VinnyVette
Good to know. I forgot to mention that my C5 has 211k miles. I'm hoping those components I mentioned can still hold up.
Old Sep 13, 2015 | 04:04 AM
Chicago1's Avatar
Chicago1
668rwhp and i beat the crap out of the car..noone of those have broken but I'm not launching on DR or slicks on the dragstrip either...
Old Sep 13, 2015 | 01:42 PM
ZZ06's Avatar
ZZ06
Have 418ci LS3 stroker here at 490rw/484tq. Still stock trans, gears, and output shafts. Like Chicago mentioned though, im not out there on a track with DR's or slicks. Im also around 123k mi. I just drive around town and have a little fun while im at it. Dropping the clutch and dead hooking with that sort of power and ill put money on things going kaboom in no time.
To LS1 Long tube headers on LS3 engine?
