F45 suspension will not clear!!
Old Sep 21, 2015 | 10:45 AM
dadaroo's Avatar
dadaroo
Need to make sure I fully understand which DTC you were using and fully understand the results you got. Just PM'd you my numbers so can discuss.
Mr. Sam
PS: Didn't think my Post worked.
Old Apr 9, 2018 | 09:38 AM
Daniel94B's Avatar
Daniel94B
Did u solve the issue ?
Old Apr 9, 2018 | 10:52 AM
midnight01's Avatar
midnight01
Originally Posted by chad911sc
I cut the wires to the sensors and discarded them. I placed the white wire on one side of the 10 watt 10 ohm resistor and the black wire on the other side of the resistor. I then plugged the connection back in line with the original plug at the wheel housing. Is this not the correct way? Let me know if I can do it differently to make it work. Thanks, Chad.
I see the issue, its the resistor. Theones I got from radio shack look nothing like those, it was white and right on it said the designation ie. 10 watt 10 ohm resistor. I did mine before my tech2 and the only error I got was service ride control.
I am in Fort myers which is 3 hours away. I would offer to help. make sure you do not unplug the bcm in the trunk until you tech2 it out.
Old Apr 9, 2018 | 01:13 PM
bravo29's Avatar
bravo29
I just did mine and didn't want the hassle of the guessing game with resisters. I bought the simulators and not one issue.
Old Apr 9, 2018 | 01:46 PM
Chicago1's Avatar
Chicago1
edit...never mind
