Today one of my beehive springs from pac racing broke. It caused cylinder 2 to drop a valve. After pulling head I see that the rocker arm is broken, the exhaust valve bent, and top of piston is scratched fairly deep. Question being: can I replace all broken components and ignore the scratched piston? No damage to cylinder wall or head. Thanks.
You bent a valve and your valve guide is still OK??
I would replace the piston just to be sure there are no unseen fractures that come back to haunt you later. But, at a minimum, you need to be sure to eliminate any and all sharp edges on the top of the piston. They will act as hot spots and potentially cause detonation. Good luck with your repair!
A buddies old Ferrari broke / swallowed a hollow core / sodium valve. The piston top had some dings in it. We examined as close as possible for cracks and I ended up just smoothing out the sharp edges with a Dremel. That was about 10 years ago and its still running!
It seems to be okay. Is there a more precise method of checking the guide?
You already have the head off why are you not taking it to a machine shop have the guide checked, check the other springs and replace the valve seals. You have already done the hard work.
As Robert Perkins suggested, a machine shop is the best place to have it checked. If that's not possible the poor man's way is to pull the spring off a good valve and compare how it feels to the questionable guide with a new valve in it.
post pics of the piston. you may be able to sand it off if it's not bad. you can use a penetrant dye to detect cracks in the piston. Use the dye before sanding.
Again, depending on how bad the valve was bent, the guide might be ok. However, if it needs to be replaced, I'd go for a new head instead of pressing in replacement guides. The stock guides are made from powdered metal, and are far superior to any brass or bronze replacement guides a shop will press in. The powdered metal guides are not available as replacements.
