Help!! Issues
Old Sep 20, 2015 | 06:07 PM
Jdean_93's Avatar
Jdean_93
Default Help!! Issues
for some reason my route 02 trim will not match the driver.. something is telling the computer that bank 2 is lean and it's commanding more fuel.. I put my wideband in bank 2 and it's actually not lean it's about perfect between 14.7 and 15.0 at idle.. I have don't continuity test and 3 02sensors I am out of ideas anyone?
Old Sep 20, 2015 | 06:16 PM
BestToyYet's Avatar
BestToyYet
Jdean 93, Wish I could help but not familiar with this issue. There are some really smart folks on here who can give you guidance. However, they are going to need some background on your car. List year, coupe/vert, any modes. As much info as you can. Seems silly but it helps them. They are going to ask for it anyway.
Wish you luck.
Old Sep 20, 2015 | 06:23 PM
BestToyYet's Avatar
BestToyYet
Also forgot to mention - list any codes you have.
Old Sep 20, 2015 | 07:37 PM
Jdean_93's Avatar
Jdean_93
98 auto targa car.. upgraded to 99 newer pcm and I have checked the wiring more times than I can count
Old Sep 21, 2015 | 02:34 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Don't really understand what you mean by this---
I am guessing that you are getting a far difference in LTFT's from the right and left banks-- Typically the side that is RICH has an exhaust leak--Even a small leak can cause as much as a 12-15% LTFT---Most likely the lean side is the true recording of your fuel trims---
Do you have LT headers ?
You could even have a plugged cat on the lean side or a bad muffler-
It is very rare to have it be a fuel flow problem on the fuel rail from left to right
If you can data log you average 02 voltages on both sides that would help--
Please explain your 1st sentence---
Also at P/T the ECM is constantly correcting the AFR on it's own so you won't get a reading that is askew on the wideband-----I suspect the problem is on the other side---
To Help!! Issues
