Normal Voltage Readings on the DIC... (Need Help)
Old Aug 23, 2002 | 04:07 PM
Jim Kramer's Avatar
Jim Kramer
Default Normal Voltage Readings on the DIC... (Need Help)
I am beginning to wonder if I might have a weak battery, or alternator... often times when sitting at an idle with many accessories going at the same time my voltage readings drop way down... sometimes even below 12 volts (high 11's). If I touch the gas a little it will jump up into the 13's or 14's, but let her run back down to idle, and it will fall back down. During normal idle during the day without the lights on etc. it seems fine. Could someone do a test for me:
With your car at an idle (in drive if it's an auto) turn on the following:
Headlights
A/C
Wipers
Driving Lamps
Radio
... and tell me what your Voltage reading on the DIC is...
It would really help me out... I want to address this if it's a defect.
Thanks!!!
-Jim
Old Aug 23, 2002 | 07:38 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Normal Voltage Readings on the DIC... (VetteMan2k1)
ttt for ya Bud :cheers:
Old Aug 23, 2002 | 08:00 PM
RGO's Avatar
RGO
Cruising
Hey VetteMan2k1 Ihave 99 coupe 6 spd........just came back from joy ride so its all warmed. At idle 700rpm. lights+ac+wipers+fogs+cd playing the DIC is at 13.4 /13.5.......oil temp210 coolant 195. original delco battery, 37636 miles on car. Hope this help ya. Bob O.
Old Aug 23, 2002 | 10:19 PM
MDT's Avatar
MDT
VetteMan2k1,
I checked your sig to see if you were running an underdrive pulley...didn't find that but spied a 400 Watt Rockford amplifier. :D I think that there is more load on the system than it can overcome at idle, especially with the amp and other accessories turned on. I don't think that you have a problem with the charging system.
Good luck.
Mark
Old Aug 24, 2002 | 08:26 AM
Jim Kramer's Avatar
Jim Kramer
Default Re: Normal Voltage Readings on the DIC... (RGO)
Thanks!!!
:cheers:
Old Aug 24, 2002 | 08:29 AM
Jim Kramer's Avatar
Jim Kramer
Default Re: Normal Voltage Readings on the DIC... (MDT)
VetteMan2k1,
Good luck.
Mark
Turning the radio (which also turns off the amp) has little or no effect on the voltage I am seeing... now the headlights are another story. I do have aftermarket bulbs in them... but I think they are stock wattages. The PIAA's also pull more than normal, I do know that!
One day my battery wnet below enough avoltage to start the car (while sitting in the garage) just from dcoing the door locks a few times!
:confused: :confused: :confused: :confused:
Old Aug 24, 2002 | 10:27 AM
rmeier's Avatar
rmeier
Cruising
Normal voltage at idle should be 13.5-13.8V with a light load. Heavy load
(lights, AC, + big amp could be lower). The battery should measure about
12.5V, engine off, dropping into the upper 11s with headlights on.
If this problem is new then one of the rectifier diodes is probably bad.
If you don't have a voltmeter I'd recomend getting one. An inexpensive DVM
can be had for about $50-$60 at a Radio shack.
Old Aug 24, 2002 | 12:01 PM
Richin Chicago's Avatar
Richin Chicago
Default Re: Normal Voltage Readings on the DIC... (rmeier)
I just measured mine at 12.2 with a RS DVM. This is with the car off and the hood light on.
To Normal Voltage Readings on the DIC... (Need Help)
