Help ! Throwing Code # C1286 ..Can't figure out why .
Old Aug 23, 2002 | 05:28 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Help ! Throwing Code # C1286 ..Can't figure out why .
My DIC reads "service engine soon " and when i pulled the codes i got code # C1286.
Has anybody else had this problem ?? Any idea what is causing my PCM to throw this code ?? Once its cleared it comes back in 15-20 mins..Car is running fine.
Thanks for the suggestions !
:cheers:
Jeff
Old Aug 23, 2002 | 06:05 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Re: Help ! Throwing Code # C1286 ..Can't figure out why . (BLUTHUNDER)
Just spoke to my Good Old trusty Tech at Anderson Chevrolet in Los Gatos. ( i miss haveing him local :sad: ) If any of you No Cal guys are looking for a great shop..I suggest you check these guys out.
He told me that there's a steering sensor located at the base of the steering column ..He's pretty sure that its damaged and needs to be replaced.
Hopefully thats all it is.
:cheers:
Jeff
Old Aug 23, 2002 | 06:14 PM
BatMobile's Avatar
BatMobile
Tropical Moderator
Cruise-In 1-5 Veteran
St. Jude Donor '03-'04-'10-'11
C1286 Steering Sensor Bias Malfunction
Best to take it in to the dealer...
I had C1287 after we disengaged the steering shaft for the header install, but that is because we put the shaft back in 360 degrees out of sync. Popped the knuckle on the shaft, spun the wheel 360 degrees, reattached, and everything has been fine ever since.
1286 I have no idea how to fix and my manuals are in my office.
:confused:
Old Aug 23, 2002 | 06:17 PM
SFVetteman's Avatar
SFVetteman
Assuming you haven’t disconnected the steering gear recently, it would have to be the steering wheel position sensor or less likely the EBTCM (electronic brake control module) unless the service active HNDLG message was displayed as well.
To test the sensor, you need a scanner. It should read 2-3 volts.
[Modified by SFVetteman, 2:30 PM 8/23/2002]
[Modified by SFVetteman, 2:32 PM 8/23/2002]
Old Aug 23, 2002 | 06:26 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Re: Help ! Throwing Code # C1286 ..Can't figure out why . (SFVetteman)
Bill / Batmobile , Thanks for the feedback ! Batmobile , did you feel something was wrong with the steering ?? Or was the problem transparent ?
:cheers:
Jeff
Old Aug 23, 2002 | 06:47 PM
The DBK's Avatar
The DBK
Wasn't there a TSB on that being a phantom code or something? :confused:
Old Aug 24, 2002 | 12:18 AM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Re: Help ! Throwing Code # C1286 ..Can't figure out why . (The DBK)
Hmm..if thats a phantom code then i'm one happy camper :yesnod:
But i doubt it , C1286 means there is a "Steering Sensor Bios Malfunction "..Whatever that means.
C4C5tech are you around ?? If so please explain..
Thanks !
Jeff
Old Aug 24, 2002 | 03:11 AM
Da Kind's Avatar
Da Kind
Umm, could this be related with your supercharger install from MMS?
Didn't they have to take the front end apart to do the install?
Good luck and I hope it is not serious.
Old Aug 24, 2002 | 11:36 AM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Re: Help ! Throwing Code # C1286 ..Can't figure out why . (Da Kind)
I'm pretty sure that it does have something to do with the ATI set up ..I wasn't throwing any codes before the install.
I'm going to bring it to the dealer and have them run some diagnostic's..I'm keeping my finger crossed in hopes that its just a damaged sensor.
:cheers:
Jeff
Old Aug 24, 2002 | 11:55 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Steering position sensor :yesnod: The column has to come out to replace it...The phantom code 1287 is on the 2001-02 second generation ABS :yesnod:
Old Aug 24, 2002 | 05:38 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Re: Help ! Throwing Code # C1286 ..Can't figure out why . (C-5 TECH)
Well i think i may have lucked out ..I just got back from a nice 150 Mile romp with the car and no codes came up on the DIC.
:D
As always , Thanks for the input guys !
:cheers:
Jeff
Old Jul 2, 2023 | 11:15 PM
Capterics's Avatar
Capterics
Hello, I'm and ASE CMAT and C1286 is phantom code. It can trigger all of the above. It may say it's a steering sensor, or a bad brake cable. A defective ABS unit can flag this and so can a missing Air Bag or E-bake bulb in the Instrument cluster. Ignore it, or spend a year trying to figure it out. It does not affect driveabilty in my C5 or my GMC Jimmy.
Old May 1, 2025 | 07:52 PM
Robojimbo's Avatar
Robojimbo
Cruising
Default Honestly mine was a near money shift.
QUOTE=BLUTHUNDER;3830475]Well i think i may have lucked out ..I just got back from a nice 150 Mile romp with the car and no codes came up on the DIC.
Hey Jeff, Recently a first time owner 99 6sp. Both times ive attempted to or near money shifted. I threw this code. One with a light and one without. But one was thrown with TS on and one Off with ancient gas in it. Which vorrected itself. Im hoping a few hundred miles ofnl being nice corrects my second one here. Steering i noticed is little more stiff.
Jeff[/QUOTE]
To Help ! Throwing Code # C1286 ..Can't figure out why .
