HELP on LS6 swap with Headers
But now that I have it all apart I have some questions. The new intake is the Dorman LS6 repo that I have done about 10 hrs of porting on and it looks much better than the way it came
My questions are now that I am installing long tube headers with no EGR provisions, what all can I remove and not put back on.
Also The back of the ls1 intake has this electrical/vacuum thingamajig and I don't know what do with it since the new Dorman ls6 has no place for this.
So I am going to place some pics in here and if you could tell me to pitch it or keep it!
Here Goes: Pic 1 is the back of the ls1
pic 2 is the ls6 dorman with 3 ports on it
pic 3 is drivers side something with vacuum ports and elec.
pic 4 is some kind of lg vacuum tubing that connects to
front of intake on passenger side.
pic 5 is the connection point of the egr on drivers side, I am
assuming I can just take all the egr stuff off both sides and
then what do I do with the black lg vacuum tube that was
connected too it?
Thanks in advance for the corvette NOOOB
You have 3 ports so hopefully they work for the MAP, AC and brake booster hoses.
Does any one know what the pic # 3 is? It was on the drivers side next to the fuel rail. It wasn't connected to anything, but it looks like it has and elbow that connected to some kind of small vacuum line. The same size as the AC blend door vacuum. There is also another port there that has a raised small circle around it? The connection on the left side of this doohicky comes from the plastic connector that is on the drivers side intake next to the throttle body. The one you have to squeeze the little light color grey plastic piece down to disconnect. I'm sure they are supposed to connect to something. As many people that have had the intake off on this site surely someone out there knows where these go>>>
