Alarm Problems
Old Oct 4, 2015 | 07:21 PM
nipper87's Avatar
nipper87
Cruising
Default Alarm Problems
In the past 3 months the alarm has gone off once on it's own and four times when I opened the drivers door after unlocking with the key fob. Possible cause?
What is the best temporary fix until I can get it to the dealer?
1. Pull the horn fuse
2. Leave unlocked (in a locked garage)
3. Program "lock and arm off" in DIC
2001 Coupe Automatic
Old Oct 4, 2015 | 07:59 PM
Chris Stewart's Avatar
Chris Stewart
Mine was doing this. I replaced the battery because it was getting old, and hasn't happened again.
Old Oct 5, 2015 | 10:40 AM
grantv's Avatar
grantv
Try the battery. If that doesn't work pop open the FOB and place a piece of black tape (around 5/16" square) over the connection point behind where the alarm button is. Your ability to set off the panic alarm now will be completely disabled however. I did it because I had set mine off in my pocket a couple times; PITA.
To Alarm Problems
