Clutch 12volt wire
Old Oct 8, 2015 | 08:33 AM
Cee5's Avatar
Cee5
Default Clutch 12volt wire
Hey everyone,
By any chance can someone tell me where I can find my 12volt wire on my clutch for 99 C5
I've been trying to look for it and I just can't find.
Thanks for the help
Old Oct 8, 2015 | 12:46 PM
lionelhutz's Avatar
lionelhutz
Maybe the 12V power to the AC compressor clutch?
Old Oct 10, 2015 | 04:58 AM
Cee5's Avatar
Cee5
Well I have a 2 step and I want it to activate with the clutch so I just heard I should run it with the 12volt that actives the clutch I'm guessing
Old Oct 10, 2015 | 07:40 AM
kmetros's Avatar
kmetros
I'm still lost. My brain is acting the same way it would if you were asking what weight oil to use when changing the blinker fluid or what sized ball bearings the mufflers take?
curious to see......
Old Oct 10, 2015 | 10:54 AM
lionelhutz's Avatar
lionelhutz
The pedal moving activates the clutch, not 12V power. You probably want to install a limit switch on the pedal.
To Clutch 12volt wire
