Lifter tap question/advice please
Old Oct 14, 2015 | 11:14 AM
John_B's Avatar
John_B
Originally Posted by vettenuts
When was the last time the valve springs were changed? You might be losing control of the valve train and hammering the lifters.
By the previous owner when he did the cam, but the car only has 16k miles on it. I'm not sure when he did the cam. I was thinking of switching to a bigger cam and doing the full valve train, but the lifters wouldn't be done with the cam unless the heads come off... Which is a lot more money and then do heads too lol
Old Oct 14, 2015 | 11:17 AM
John_B's Avatar
John_B
Originally Posted by SaberD
Do you know if the heads were pulled? If so, and new pushrods were added, preload could be the issue. If they sized the pushrods on the short end of the spec, when the engine gets really hot, aluminum expands, and could reduce lifter preload by as much as 0.01" putting the preload out of spec. The GM spec is anywhere from 0.05 to 0.1" of preload. However, most people recommend 0.08 to 0.09 preload for the quietest valvetrain.
On the other hand, they could have just re-used the stock ls1 lifters which aren't the greatest with an aftermarket cam especially when the miles start to build up.
Could also have had some sort of contaminant in the lifter that caused it to stick, and you may never see the problem again.
I wouldn't worry about it unless it happens again.
Is this an LS1 or LS6? year?
It's an ls6, 2002 Z06 with 16k miles. Cam was installed by previous owner and I'm really unsure of what exactly was done and when, but was told "springs and all the stuff that goes along with the cam were done" so my guess is as good as yours unfortunately.
I'm hoping I never have it come back, just being paranoid, I've gotten on the car many times and this is the first it ever happened. So maybe it was a freak thing but I just don't want to chance it
Old Oct 14, 2015 | 12:08 PM
SaberD's Avatar
SaberD
if you do decide to tear into it, definitely replace the valve springs. They are prone to failure in some 02-03 z06 models. There is range of vin #'s for the cars with this problem. Research and you can find it. If yours falls within this range, I would definitely replace the springs.
https://www.corvetteforum.com/forums...vins-pics.html
Old Oct 14, 2015 | 12:18 PM
John_B's Avatar
John_B
Yea I know the springs are prone to failure. I was told they were replaced but I can't be 100% sure without opening it up.
Old Oct 14, 2015 | 12:57 PM
John_B's Avatar
John_B
I'm wondering if the best thing to do is replace the springs. I don't see any cam packages that come with lifters. It doesn't seem common to replace them.
Old Oct 14, 2015 | 03:16 PM
SaberD's Avatar
SaberD
A quick check wouldn't hurt. It doesn't take much to get the valve covers off. then you could check for any play in the rockers that would indicate stuck lifters or bad needle bearings. You could also ensure the springs were replaced.
Also, the ticking that you hear from an exhaust leak particularly at the exhaust manifold gasket is valvetrain noise. Might be worth going around all the exhaust manifold bolts and making sure they are snug.
