Oil pressure Question..
Old Aug 25, 2002 | 03:50 AM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Oil pressure Question..
What is considered safe Oil pressure ?? Is 60 PSI too high ?
Jeff
Old Aug 25, 2002 | 04:37 AM
Quick Brick's Avatar
Quick Brick
Default Re: Oil pressure Question.. (BLUTHUNDER)
60 is fine. When it is cold it can be higher due to viscosity. The old minimum rule of thumb was 10 psi per 1000 rpm. The more the better or something :crazy:
Old Aug 25, 2002 | 03:49 PM
carpe dm's Avatar
carpe dm
Many C5s seem to run around 40psi, once they warm up. Higher when cold. I just changed to a lighter weight oil and my psi dropped a pound or two. :)
To Oil pressure Question..
