'01 vert basic displays Traction Control and ABS problem ????
Old Oct 14, 2015 | 08:10 PM
C4DERF's Avatar
C4DERF
Default '01 vert basic displays Traction Control and ABS problem ????
On my ride home from work I was at a stop light when all of a sudden the Traction Control and ABS fault lights lit-up on the dash. How can I clear the warning lights everything seems to be working fine??!!
THANKS FOR ANY HELP IS APPRECIATED.
Old Oct 16, 2015 | 12:45 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
T/C and ABS messages or codes are most often related to a fouled or broken wheel speed sensor---The pigtails get dirty and won't read--the wires can get frayed or broken--
I would check all 4 of them---One at each wheel--around the brake rotors
The data from the wheel speed sensors is used both by the ABS system and the Traction control system-----The ABS uses the sensors to detect if the wheels are skidding on a hard stop---and the T/C uses the sensors to detect if the wheels are spinning on a hard launch----
Also often times on older cars simply driving on a rough road or going over railroad tracks will trigger the codes as the pigtails momentarily become dis connected
Try clearing all the codes 1st---How to on the forum----If they re-appear then is wasn't a one time thing and next I would check all the sensors
Old Oct 16, 2015 | 01:04 AM
BigGun's Avatar
BigGun
If you pull the codes you will know if you have a speed sensor problem or if it is something else causing the problem. The code will even indicate which wheel is suspect.
To '01 vert basic displays Traction Control and ABS problem ????
