A/C actuator problem with a twist
Like many folks, I've had a problem with the left and right a/c actuators. When in a/c mode, air is not flowing through the correct registers. In fact, no air is coming out anywhere, but the blower is working and you can feel air escaping from around the lower dash housing. It's throwing code B0367 which is "Right Actuator Feedback Open." I was able to cure the problem three or four times by pulling fuse #27 for over 60 seconds, then replacing it. That no longer helps.
Here's the twist. I have automatic climate control and when I set it to the lowest temp (60 degrees), air comes out of the proper registers with the fan at full speed. (I can turn the fan down and it still works.) As soon as I set a higher temperature, the problem returns.
But for the "twist" and the right side only code, I would have thought that my actuator problem was the same as those many others have experienced. Obviously, something is different.
Has anyone seen this problem?
Thanks,
Chas.
Normally when it is vacuum it causes air to come out of the wrong locations, not none at all.
Not sure how you want to diagnosis at the moment but I am wondering if you have an issue with the actual Dual control head unit also.
If you look at B0367 it can be several things including the actual actuator or the head unit.
You can let me know where you would like to try and start and I can provide FSM guidance and some DIY Threads.
Just so you have B0367, here it is.
https://www.dropbox.com/s/twwpokxtfn...B0367.pdf?dl=0
Mr. Sam
I admit that I don't know where to start. The fact that I can get airflow through the correct registers when the temp is set to maximum cooling (60 degrees) makes me think it's the dual control head, rather than a vacuum problem. Would you agree?
If it is the control head, then I don't know if that's reparable. I've had it out once to fix the cold solder joints on the resisters that caused the dim readout problem. (The fact that the problem was corrected three or four times by pulling fuse #27 is also puzzling.)
Thanks again.
Chas.
Mr. Sam
Swapping it out is easier than pulling the dash.
If you want to get a unit I would recommend Marc at VetteNuts.net. Great Forum vendor here. If that does not resolve it we can find the answer and you still have a good unit to sell or keep.
Doing the diagnostics means you need to have some basic knowledge of measuring voltage and resistance with a Multimeter.
Mr. Sam
Here is a link to order: http://www.vettenuts.net/index.php?l...ct_detail&p=68
