A DRL LED Wiring Challenge!
Old Oct 20, 2015 | 11:54 PM
formula1nut's Avatar
formula1nut
Default A DRL LED Wiring Challenge!
I have a US purchased 1999 Coupe. In Canada we are required to use DRLs. There is NO requirement for amber turn signals. I would like to add LED DRL light strips. They would not replace any existing lights, rather provide additional lighting.
In a perfect world I would like the LEDs to function as DRLs along with the existing ones BUT when I turn on the signal they would flash along with the signal. In other words they would be steady on unless I activate the signal at which point they would flash clear. Once the turn is completed they would revert to steady on.
Can you assist me with how I can achieve this in terms of wiring and relays?
Thanks in advance!
Old Oct 21, 2015 | 09:13 PM
formula1nut
Originally Posted by AUandAG
I added led's which function just like oem about 6 months ago. I'll try to find my diagram. You'll need 4 diodes and 2 resistors.
That would be great! To be clear though I am not looking to duplicate the OEM lighting. Rather I want OEM functionality AND flashing with the turn signal.
Thanks!
Old Oct 21, 2015 | 11:34 PM
lionelhutz's Avatar
lionelhutz
What's wrong with hooking them to the DRL/Signal bulb power feed?
Old Oct 23, 2015 | 09:25 AM
formula1nut
Not to sound like a fool but I don't understand what you mean. I think the signals and DRLs are independent circuits...no?
Old Oct 23, 2015 | 10:12 AM
lionelhutz's Avatar
lionelhutz
No, same circuit.
Old Oct 23, 2015 | 12:39 PM
dadaroo's Avatar
dadaroo
Not sure if that will give you hyperflash, may or may not.
You would be adding an additional load on that circuit. I doubt just a few pure LEDs will be a problem but if for any reason you blow a fuse DO NOT put in a larger fuse.
Mr. Sam
Old Oct 23, 2015 | 12:50 PM
formula1nut
Default I am confused!
I am totally confused. The LEDs are two wire...ground and power.
I am 99.99% positive that the DRLs do not flash with the signal presently. So how would I do the wiring to get them to be steady on only interrupted by flashing with the appropriate turn signal?
Hyperflash is not an issue as I have already installed LEDs at the rear.
Old Oct 23, 2015 | 06:15 PM
lionelhutz's Avatar
lionelhutz
The filament that lights up for the DRL function is also the turn signal so of course if flashes with the signal.
Old Oct 24, 2015 | 06:15 AM
dadaroo's Avatar
dadaroo
The OEM stock bulbs have two filaments in them. One for the DRL/Turn Signal and one for the Parking light.
I have no idea what your setup is or what you are trying to replace it with.
Mr. Sam
Old Oct 24, 2015 | 07:28 AM
formula1nut
Mr. Sam
I want to leave the existing light functionality and add the LEDs such that they do the same as the existing two filament bulb. My LEDs are not switchchback just 2 wires.
Old Oct 24, 2015 | 01:21 PM
dadaroo's Avatar
dadaroo
OK, I understand, then you want to tie the LEDs into the circuit for the DRL/Turn Signals. If you need wire colors we can provide that. On each side, one wire would be connected to the power in and the other to the ground side of the existing lights.
The LEDs have a polarity so you will need to figure out which wire is power versus ground on the LEDs. That is easy to do by testing using the battery.
Mr. Sam
Old Oct 24, 2015 | 02:10 PM
formula1nut
Mr. Sam
Thanks. I am familiar with LEDs and can easily pre-sort the polarity. Remember I have two wire non switchback LEDs. I am still trying to understand where I would hook up the power side of the LEDs. Can I simply splice into the LED wiring giving it two feeds then use one for each existing socket?
Old Oct 24, 2015 | 03:08 PM
Stroker87's Avatar
Stroker87
not sure i follow but it would be very simple if you install "switchback" bulbs in stock front turn signal locations there white until you use a turn signal then switch to amber then back to white once the turn signal is turned off
Old Oct 24, 2015 | 03:31 PM
formula1nut
https://www.youtube.com/watch?v=XOn-7pTAuRk
Thanks. I know switchbacks are dead easy. My problem is that I bought a set of corner lights with non switchbacks installed inside and would like to use them..
Old Oct 24, 2015 | 07:21 PM
lionelhutz's Avatar
lionelhutz
So, you want them to light up as parking lights as well as DRL as well as operating as signal lights?
Old Oct 24, 2015 | 08:55 PM
formula1nut
No not parking lights; just DRL and signals.
Old Oct 24, 2015 | 11:26 PM
lionelhutz's Avatar
lionelhutz
OK, hook to the signal and ground wires in each corner light. I believe it's the dark blue at one corner and light blue at the other corner for power and black for ground.
If you don't include parking lights then it isn't the same as the 2 filament bulb functions.
To A DRL LED Wiring Challenge!
Old Oct 25, 2015 | 07:01 AM
dadaroo's Avatar
dadaroo
Verified with the FSM.
The power wire for the left DRL/Turn Signal bulb is Light Blue/White.
The power wire for the right DRL/Turn Signal bulb is Dark Blue/White.
Ground is Black on both sides.
Mr. Sam
Old Oct 25, 2015 | 09:20 AM
formula1nut
Great. So to be clear if I do this the LEDs will be on always as DRLs and flash with the signal?
Thanks all!
Old Oct 25, 2015 | 09:59 AM
dadaroo's Avatar
dadaroo
Yes, they will work exactly the way you want but you may end up with hyperflash which you can resolve with a Hyperflash harness.
Mr. Sam
