I am ready to install the adj. MC and I have a few questions. I transferred over all of the rubber gaskets for the firewall and for the mount. What is the easiest way to install this? I pulled the stock MC out without removing any items. Does the clutch line go under or over the Steering shaft? Thanks
Phillip :crazy:
Re: Need some install tips for Mcleod Adj. Master.. (Phil97SVT)
Removal of the factory MC: 10 minutes
Disconnect factory connector between MC and Slave
unhook MC rod from pedal
Rotate MC 45 degrees and remove
Installation of Adj. MC: 20 minutes
Transfer all rubber gaskets
zip tie rubber hose for fill tube
Install MC with hose straight up and rotate 45 degrees clockwise.
Phillip :smash:
