Installed the hurst (self explanotory). Love it. Used the flapper from a toilet (yes a new one :smash: ) cut the plastic flange around it off and slid it down the shifter shaft...dampens vibration much like the small rubber boot on the base of the stock shifter...cost $1.19.
Installed the Frost King Duct insulation for noise/temp insulation. Did the entire interior, hatch, both passenger cabins, and tunnel. (see this link for the install http://mikemercury.home.att.net/sound.htm ...this is where I got the idea). Took alot of time, about 8 hours, but well worth it. I can actually drive at 75mph on the highway and talk in a conversational tone!!! :D
Cost = 5 rolls@ $15/roll
Let me know if anyone else has tried this. If you haven't, and you have a free day on the weekend it's worth it for $75 bucks. My advice is get at least one buddy to help you out with it.
Hey that is awesome. I am really thinking about doing that on my convertible, maybe starting with the cabin then the truck if needed.
Have you tried or heard of the heat shield that is being offered at a site that I cant seem to mention here? Its a bit expensive and was wondering if its worth it in addition to your mod.
I wonder how much weight this ads to the car? I know I am being ****, but isn't this why GM left this out in the first place? Or, was it the almighty $$$?
Corey, Mike Mercury states the weight per roll as 3 lbs. He used 5 rolls for a total of a 15 lb. increase in weight. Pretty insignificant for such a large improvement in heat and sound insulation, I'd say.
I plan on doing this in the near future as well. :cheers:
I'd like to once again tip my hat to Tim (Mike Mercury) for his contributions via his web site and posts. His attention to detail is highly appreciated. :flag
I did this project some time ago, including the fender well spray job. Did a good job on the noise level, but will try to find a better heat reflector to use on the tunnel next time. :)
That is very little weight. I could stand to lose double that off my ****! :lol: How much of a difference in sound does it make? I want it to be caddilac quiet! :yesnod:
**** Finger-- I've heard of that heat shield, but isn't it a couple hundred$ ?Too much IMO.
SAXN8R--It's really light...no worries there...there isn't much out there that is lighter
Carpe DM--I didn't do the spray in the fender well, I've heard of putting standard (fiberglass) insulation in there but I'm not touching that right now. As for heat, this stuff is rated up to 200 degrees, I covered the whole tunnel when I had the console out. Seems to have a really good effect. Mike Mercury talks about using "Reflectix" for this and I've seen it done on others. Reflectix is not self adhesive though, so you could have some trouble with it.
Well it's not "Cadillac Quite" but compared to "stock" it's a fairly dramatic difference. My buddy and I got in when we were done took off. We were talking about it, and tryin to listen for the difference. He says, yeah it helped some, but...then we realized we were actually speaking at a normal volume. I dropped his azz home and popped in a cd...much more clarity and I could here parts of the song I'd never heard before.
I also learned the value of the heat insulation...on the way home my girlfriend calls and asks me to bring home some dinner. I stop off at Bojangles and realize that I don't want fried chicken anywhere near the front seats so I stick the box in the center storage well in the hatch. I drive home (a good 1/2 hour drive), open the rear compartment and whooosshh I get hit with the heat from the chicken!! :lol: The chicken was just as hot as it was when I bought it!!!
Moral of the story, you can earn money delivering chicken to counter the installation costs!
You can probably get the same results with $15, some spare time, and a little elbow grease. (The reflectix material is rated to higher temps and is found in the building materials section of Home Depot and Lowes; "Reflectix" is the brand name http://www.reflectixinc.com
Well, if you add the insulation you can buy it raw and cook it on the way home :D :D :D :D
A flapper from a toilet? :lol: Did you get the handle too? You could replace your gearshifter with the handle, and flush the competition!!! :lol: :lol: :jester
I'm just playin"! That's a great idea to keep costs down. :cheers:
