Code help please
Old Oct 30, 2015 | 06:15 PM
Vanover's Avatar
Vanover
Default Code help please
I pulled my codes,this is what I got.
B 0502 HC
B 0507HC
B 2482HC
B 2605 H
C 2100 HC
Anybody know what there are?
Old Oct 30, 2015 | 07:31 PM
ONE BMF's Avatar
ONE BMF
B 0502 HC
B 0507HC
B 2482HC
B 2605 H
C 2100 HC
None of them are any real serious issue thankfully! B0502 RH DRL Relay Circuit, B0507 LH DRL Relay Circuit, B2482 Backup Lamp Relay Circuit, B2605 Seat Front Vertical Position Sensor Failure, C2100 Left Front TPM Sensor Malfunction Save this to file , its your best friend ! https://www.corvetteforum.com/forums...s-from-gm.html
Old Oct 30, 2015 | 08:17 PM
Vanover's Avatar
Vanover
The DRL,I pulled the #2 fuse because of the heat they make,I'm going to change them to LEDS.that explains those. Backup light,could it poss.be related to that circuit? As for the seat it is working fine.i did reset my memory,maybe that's the seat code.the TPMS,LF on display is reading XXXX.so maybe the batt?or try to retrain? Thanks for the help
8vette7 hope it was ok to IM you
To Code help please
