Spark Plug Change?
Old Nov 2, 2015 | 10:34 PM
Glock 23C's Avatar
Glock 23C
Default Spark Plug Change?
2001 Coupe-Stock. I am looking for advice on if or when I should change out my spark plugs. I have just over 50,000 miles on the car. It is driven pretty easy with occasional hot runs down ramps or long stretches. It runs great. Since my car is not driven year round like a normal car, i wonder if the owner's manual is a good reference for this maintenance. I drive it April thru November and then park it for the winter. I am interested in the opinions of folks a lot smarter than me on these matters. And how about plug wires or other related items I might consider to change out performance related. Thx for your time and advice.
Old Nov 2, 2015 | 11:25 PM
dork's Avatar
dork
If they're the originals I'd change the plugs just because they've been for 14 years. I'd recommend a change just so you can start the clock over again. I changed mine out when I installed headers (at 12 years and 75,000 miles) and it took a breaker bar to break mine loose. I was praying and sweating each plug I removed. At least six of mine were in *extremely* tightly.
Coat each new plug with anti-seize and each boot with electrical grease so the wires don't stick to the plugs. Everything I've read says that the vast majority of owners tear at least one plug wire and the general recommendation is to replace the set with the plugs anyway.
Old Nov 3, 2015 | 12:00 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Your car is 14 years old---I would deff. change the plug wires----I like the GM RED wires the best
As for the plugs---These new material plugs can last 50-100K miles--
The problem is if you have never taken them out yet or if you wait til 100K miles to change them-- the plugs get stuck in heads--They sorta get carbon welded into the holes---Often you will break them in two when removing them OR strip the threads
Old Nov 3, 2015 | 10:45 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
It's a chore for sure. Care and patience are required. Getting the old boots off was the hardest part for sure when I changed mine at ~60K miles.
Old Nov 3, 2015 | 12:02 PM
grantv's Avatar
grantv
I would change it out; plugs and wires (you'll never remove the wires without breaking them). I did it last year at 40K miles when I did my headers. After so many years, why not.
Old Nov 3, 2015 | 12:54 PM
Glock 23C's Avatar
Glock 23C
Thx for the input guys. I will replace both wires and plugs to be on the safe side. It will happen either this fall or in the spring.
Old Nov 3, 2015 | 01:20 PM
StingrayRebel's Avatar
StingrayRebel
nice user name, I have the non-compensated version myself
Old Nov 3, 2015 | 03:41 PM
Big_George_S's Avatar
Big_George_S
Good choice, review the post on how to, the rear plugs are tough to get to be patient and use a good spark plug socket with a knuckle. the sponge in the socket will help you hold in the plug when you go to replace them. Definitely us anti-seize on installation of new plugs.
Old Nov 3, 2015 | 08:33 PM
Glock 23C's Avatar
Glock 23C
I don't want to turn this into a gun thread, but since you brought it up I am kind of a Glock head. The Gen3 23C for off duty and the Gen4 23 for duty. And then there are the Smith revolvers. Vettes and Guns for hobbies--Ain't America GREAT? USA! USA!
To Spark Plug Change?
