Clunking noise when changing torque
Old Nov 5, 2015 | 06:29 PM
old Rip's Avatar
old Rip
Navigator
Default Clunking noise when changing torque
03 convertible has a clunking sound in rear when driveline changes torque. I originally hoped it might be CV joints but putting it on a hoist and checking those proved fruitless. It did sound like it might be inside the transaxle. We could hear it easily be moving the tires back and forth.
It sounds like lash that is getting more pronounced.
I took it to my local Chev dealer and they found a bulletin sent out from GM ( Document 2006867 ) (#PIP3896) that basically says that this clunking is normal when the vehicle is equipped with the Tremec 6-speed Manual Transmission. The document calls it normal torque reversal.
I am wondering if anyone else had this noise on their 6-speed and has resolved it. It doesn't sound like a normal thing to me, it bugs the hell out of me!
Any ideas?
Old Nov 5, 2015 | 11:30 PM
striper's Avatar
striper
Try loosening your rear axle nuts, tapping back the axles and greasing the splines, retorque the nuts. There is a good chance this will fix it. Sounds similar to mine and it worked.
Old Nov 6, 2015 | 07:51 AM
Cybermind's Avatar
Cybermind
Some backlash is normal with 6-speeds but there shouldn't be any significant noise associated with it. If there is a clunking noise, it's normally your rear axle splines.
Old Nov 6, 2015 | 07:39 PM
old Rip's Avatar
old Rip
Navigator
I saw a thread earlier that addressed this but it seemed like a dissimilar problem. I Think I know how to do this and I will try it, sounds like it is too good to be true. I am thinking about using the chainlube method!
Thanks so much for the response!
Old Nov 6, 2015 | 07:43 PM
old Rip's Avatar
old Rip
Navigator
I see that others have had a similar problem now, so I am feeling more comfortable now!
Thanks Striper and Cybermind!
Old Nov 9, 2015 | 09:54 AM
SaberD's Avatar
SaberD
new engine and transmission mounts will drastically reduce the backlash.
Old Nov 10, 2015 | 06:57 PM
old Rip's Avatar
old Rip
Navigator
I will try the greased axle splines first. I will be putting it on a hoist, and while I have it up there, will check the mounts!
Thanks for the direction.
Old Jun 4, 2024 | 10:49 AM
03BlackVert's Avatar
03BlackVert
Default 03 z06 drivetrain backlash FIXED - Thx Forum
Took real wheels off this morning to check on axle nuts. Found them to be tight but certainly under recommended torque. Tighened them up and BACKLASH IS GONE. I've got a big smile on my face today, and certainly want to thank all of the help this forum has to offer. There are some really smart C5 owners here - THANKS
To Clunking noise when changing torque
