Please help with HVAC Codes
Old Nov 6, 2015 | 11:35 AM
STRMLNE's Avatar
STRMLNE
Default Please help with HVAC Codes
The driver's side air conditioning is not blowing cold while the passenger side is fine. I pulled the codes as suggested (thank you) and came up with the following:
361H (left actuator feedback short to GND)
363H (left actuator open)
441HC - (left actuator out of range)
Does anyone know what the "cure" is for this problem(s)?
Thank you!
Old Nov 6, 2015 | 12:34 PM
STRMLNE's Avatar
STRMLNE
Than you for the reply. I tried what you suggested but the Ac is still warm on driver and middle vent while cold on passenger 2 vents.
Originally Posted by 8VETTE7
Have you cleared the codes then driven the car and re-pulled codes to see if they come back???
If so and they come back then it is worth trying this:
https://www.corvetteforum.com/forums...-for-free.html
Old Nov 6, 2015 | 12:58 PM
STRMLNE's Avatar
STRMLNE
Yes. Same three.
Do you still have the same 3 codes???
Old Nov 6, 2015 | 02:23 PM
Ray 2000 C5 FRC's Avatar
Ray 2000 C5 FRC
Neighbor had a similar issue, the fix was adding a few pounds (cans) of freon. I did not check their DIC for any codes, but the added freon put things back to normal.
Old Nov 7, 2015 | 12:59 AM
BigGun's Avatar
BigGun
If the codes and symptoms come back after the reset you will need to replace the actuator. Been there and done that. The replacement made by Dorman is much less expensive than the GM replacement and so far has been a reliable unit.
Old Nov 7, 2015 | 01:02 AM
BigGun's Avatar
BigGun
You were lucky. That only works if there are no codes and the system is actually low.
To Please help with HVAC Codes
