X - Pipe
Old Aug 26, 2002 | 11:00 PM
HPfisterer's Avatar
HPfisterer
Default X - Pipe
I purchased a Corsa X pipe at Carlisle this past week-end. I'm now researching Headers. If I install the X pipe before I select my headers, will I be limited to a a specific manufacturer? The last thing I want to do is cut the pipes to put the X pipe on only to find out that I have to scrap the x pipe because it doesn't go with the Header's I chose. The main reason for the X pipe was to eliminate the crackling and popping on back-off. Is there one set of headers that works better with the Corsa X and the Corsa exhaust. Thanks.
Old Aug 27, 2002 | 12:36 PM
redriverjohn's Avatar
redriverjohn
Default Re: X - Pipe (HPfisterer)
Contact Paul Santiago at CORSA Performance customer service:
http://www.corsaperformance.com
E-mail him and he'll get back to you within 24 hours. They have great customer support and they'll be glad to help you out. Or you can call 'em. They have an 800 number. You'll have to get it off the web site though, I can't find it in my files.
Old Aug 27, 2002 | 12:39 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default Re: X - Pipe (redriverjohn)
800-486-0999 :)
Old Aug 27, 2002 | 01:11 PM
Patches's Avatar
Patches
You can at least scratch the FLP's off your list - you must use the x-pipe that comes with their setup. I had to pull my excellent MagnaFlow x-pipe off when I installed the FLP's. :cry
Old Aug 27, 2002 | 01:57 PM
cscollis's Avatar
cscollis
I got TPIS headers and they work great with the corsa Xpipe. The xipe is after the cats so any header that doesnt include a xpipe should be fine.
Old Aug 27, 2002 | 02:00 PM
vstella's Avatar
vstella
Default Re: X - Pipe (cscollis)
My TPIS fit great with the Corsa Indy's...:D
To X - Pipe
