Will these C6 wheels fit my C5
Old Nov 13, 2015 | 12:00 PM
Csalads09's Avatar
Csalads09
Default Will these C6 wheels fit my C5
Hi All,
I have a 1999 C5 and found these wheels on Craigslist and was wondering whether or not they will fit. Would I be able to just bolt them up or would I need to obtain spacers?
http://cnj.craigslist.org/wto/5271130448.html
Where can I find the correct spacers (if I do in fact need them) for this?
Would these suffice, assuming I only need them for the rear?
http://www.ebay.com/itm/5MM-CORVETTE...pV3inQ&vxp=mtr
Any and all input would be appreciated. I would think I could just bolt them up. Also, would the TPMS in the C6 wheel sync with the C5 computer?
Old Nov 13, 2015 | 09:22 PM
DaDuck's Avatar
DaDuck
Originally Posted by Csalads09
Hi All,
The C6 sensors will not work on a C5.
You will probably need spacers on the rear wheels because you won't like how the tire is recessed into the wheelwell.
So you are looking at 4 sensors, labor to install C5 sensors on the C6 wheels, and maybe 2 spacers. probably $250.00 to $300.00 depending on what the Tire Shop charges to swap the sensors.
Old Nov 13, 2015 | 11:09 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
you will need to get 7/8" thick adapters for the rear. the front will bolt right on. the ones you linked from ebay you would need longer wheel studs and even still the wheels most likely wouldn't center and cause vibrations.
you would need this type
Amazon.com: (2) 25mm (1 Amazon.com: (2) 25mm (1") 5x4.75 to 5x4.75 Hubcentric Wheel Spacers for Chevrolet Corvette Camaro Pontiac GTO: Automotive
To Will these C6 wheels fit my C5
