Hood Stop Unavailable?
Old Nov 16, 2015 | 12:03 PM
kflohrit's Avatar
kflohrit
Default Hood Stop Unavailable?
The car was missing the rubber on the front Adjustable Hood Stop studs. I ordered a pair from Corvette Central and when I received them they were the wrong diameter and threading. I had no idea there was any reason to question the threading, but according to CC, at some point GM changed them and the ones I received are the only ones available. Anyone have a solution short of drilling and tapping the holes to accommodate the larger 8 mm x 1.25 threading? I could drill it out and just put a nut on both sides as well, but I'd rather it be the way it was intended rather that rigging it. I also considered pulling the rubber off the new ones and installing them on the old ones, but they won't fit there either.
Old Nov 16, 2015 | 12:30 PM
feeder82's Avatar
feeder82
Try mark@vettenuts
Old Nov 16, 2015 | 12:38 PM
kflohrit's Avatar
kflohrit
Originally Posted by feeder82
Try mark@vettenuts
I will do that. Thanks!
Old Nov 16, 2015 | 01:37 PM
NITRO UK's Avatar
NITRO UK
Hi
Could try here also , the stops near the windshield are shorter length than the ones on the front hinge assembly just a FYI other colours available .
http://www.ecklerscorvette.com/corve...1997-2004.html
Cheers
Old Nov 16, 2015 | 01:51 PM
NITRO UK's Avatar
NITRO UK
Link might be bad , info below on ecklers site .
Corvette Hood Adjuster Bumper, Urethane, Front, White, 1997-2004
1997-04 (C5) White Urethane Hood Front Adjuster Bumper
Part #:
25-261414-1
Price:
$6.99 ea.
Old Nov 16, 2015 | 04:04 PM
kflohrit's Avatar
kflohrit
Originally Posted by NITRO UK
Hi
Cheers
Yes, I've done a lot of research and digging to find a more specific detail of the part. I need to know more than a part number unfortunately. Since they only give a part number and not a thread diameter and pitch, I don't know what I'm buying.
Part #:
25-261414-1
Price:
$6.99 ea.
Thanks. Unfortunately I've looked at every site and no one sells the one I need listing the thread and pitch. I emailed VetteNut but they would only sell me hinges with the studs installed instead of just removing them and selling me the studs.
Old Nov 16, 2015 | 05:59 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
If you don’t want to drill and tap for the new thread and pitch, or totally drill out and use a lock nut, then maybe buy a grade 8 stainless steel bolt in the proper thread and pitch for your car. Either a hex head or carriage which ever may allow you to transfer the rubber from the new ones to the bolts. Just a thought. Good luck.
To Hood Stop Unavailable?
