Longer oil filter?
Old Aug 27, 2002 | 02:14 PM
Shag Finger's Avatar
Shag Finger
Default Longer oil filter?
On my other cars I always ran a longer (deeper) oil filter. Is there one that will fit the 02?
Old Aug 27, 2002 | 03:14 PM
SAXN8R's Avatar
SAXN8R
Default Re: Longer oil filter? (**** Finger)
I am sure there is, but you do not want it. The oil filter right now is slightly recessed under the bottom of the car. If you go any longer it will stick below the lowest point and be suceptable to damage/puncture. You are asking for trouble if you do this IMHO. Somtimes stock is that way for a good reason. If you use a good quality filter and change every 3000 miles or more you will never have a problem.
Old Aug 27, 2002 | 04:43 PM
MySea6's Avatar
MySea6
Default Re: Longer oil filter? (SAXN8R)
What he said ^ :yesnod:
Old Aug 27, 2002 | 04:53 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Re: Longer oil filter? (MySea5)
Yes, it is already slightly vulnerable where it is. I could not imagine having it any lower.
Old Aug 27, 2002 | 05:36 PM
carpe dm's Avatar
carpe dm
I use the Amsoil SDF32 filter, which is about 1/2" longer and does not pose a clearance problem. I would NOT go longer. :sad: :eek:
Old Aug 27, 2002 | 06:16 PM
RCswish's Avatar
RCswish
Default Re: Longer oil filter? (carpe dm)
I always wanted it a little shorter since my car is so low.
Old Aug 27, 2002 | 06:20 PM
pewterhdtop's Avatar
pewterhdtop
The Amsoil SDF-32 is also the longest I am willing to go! The location just isn't right for anything longer. If you follow the recommended filter change interval, you should be fine! :cheers:
To Longer oil filter?
