need help weird symptoms/ low voltage
Old Nov 21, 2015 | 03:13 PM
brookman's Avatar
brookman
Default need help weird symptoms/ low voltage
2000 coupe
I will start this with the detail leading up to now:
I drove home from work on Saturday 25 miles, turned the final corner to drop off my car pooler and got to the stop sign and the car died . it took 2 attempts to get it started again.
I did not drive it yesterday. This morning I head over to his house and it took 3 attempts to get the car started, it did not turn over slowly, it just did not fire. Then on the third attempt it started.
I helped him install a garage door opener, then when I went to leave an hour later it took 4 times to get it started, same symptoms and during one of the attempts it shows low voltage.
I came home and shut it off, went to start it again and the dash is blank all gauges at 0 and it starts with the dash completely like it is off. It is not running well however.
I shut it off and turned the key to run the dash went through the normal routine then all gauges went to 0 and I could see some of the warning lights really dim. I shut the key off and it says LOW VOLTAGE.
So I went to Costco and bought a new battery.
Even with the new battery I have the same symptoms, and I have no idea what is going on.
I shut the key off and checked the battery 12.7V.
Has anyone run into this issue?
Old Nov 21, 2015 | 03:24 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Sounds like it could be the ignition switch, there are a few posts on this !!! (Bill Curlee)
Old Nov 21, 2015 | 06:19 PM
corvette77's Avatar
corvette77
Same symptoms mine had when it needed to be replaced.
Old Nov 21, 2015 | 07:34 PM
brookman's Avatar
brookman
That is what I was hoping to hear. I could get it to run but it probably because the fuel pump primed during the initial turn of the key.
I will find his thread and see if I can rebuild the ignition switch.
THANKS !!!
Old Nov 21, 2015 | 08:00 PM
BigGun's Avatar
BigGun
You should check the connections at the starter and battery (clean and tight at both ends) before you tear into the ignition switch. There are also tests for the switch which should be done before replacing or attempting repair. Read post #3 and pull the codes.
Old Nov 21, 2015 | 08:30 PM
brookman's Avatar
brookman
The starter turns every time I turn the key and the battery is brand new.
After reading most of the ignition switch repair thread, the symptoms mimic a high resistance scenario. I am going to check out the switch tomorrow and see what I find.
Old Nov 22, 2015 | 02:49 PM
brookman's Avatar
brookman
SUCCESS! That is what the problem was , the switch needed cleaning.
https://goo.gl/photos/zjKpD1Y2iFtvDraG8
the link is to a few pictures I took of the procedure.
First 2 pictures show the switch still connected.
The 3rd picture shows the wire routing for the wire for the chip(resistor) detector.
4,5,6,7 show where all the tabs are to remove the green cover.
8 shows the view with the green cover removed. The top left has popped out of place slightly and you can see the burnt contact.
9 is the view with the moving contacts removed you can see the upper right and upper left contacts are burnt.
10 is me testing.
I used bill's excellent guide here: https://www.corvetteforum.com/forums...ch-repair.html
Thanks to everyone that replied.
Old Nov 22, 2015 | 03:16 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
even a blind squirrel finds an acorn once in a while !!!!!! (me) Glad you got it fixed !!! (and you did it yourself !!!!) $$$$$$$
Old Apr 15, 2023 | 08:01 PM
No More Harley's Avatar
No More Harley
Didn't finish reading all of the above but I did have the BCM repaired / replaced? about 1 year ago. Seemed like an honest repair shop in Frederick, Md. My good mechanic contact who knew a good contact, etc. Feel like I'd trust them to try again- Clearview Car Care, So. Wiser, Frederick, Md..
Interesting you say the BCM module since that is what he said as well- did something about it- and maybe an issue again
D
Old Apr 16, 2023 | 10:30 AM
grinder11's Avatar
grinder11
D
What model year are you talking about?
Old Apr 16, 2023 | 06:25 PM
No More Harley
1999 C -3
I will be asking for help on my problem next week.
Old Apr 17, 2023 | 06:29 PM
grinder11's Avatar
grinder11
1999 C -3
A '99 is a C5, NOT a C3!!
To need help weird symptoms/ low voltage
