Dual climate control
Old Nov 27, 2015 | 01:03 PM
Deacon Widener's Avatar
Deacon Widener
Default Dual climate control
I have a '99, and driver side vents blow cold only. A while back it was similar problem on passenger side but would only blow hot air, $600 and new actuator and problem fixed. Am I looking at same thing for driver side? Thanks.
Old Nov 27, 2015 | 02:06 PM
dadaroo's Avatar
dadaroo
Probably, DIC codes sir.
Have you tried to do a Recalibration of the actuator?
Mr. Sam
Old Nov 27, 2015 | 02:09 PM
Deacon Widener
Mr. Sam
No...how do I do that?
Old Nov 27, 2015 | 04:33 PM
zachaeous's Avatar
zachaeous
Here you go:
Re-Calibrating Actuators
Use the following steps to perform the calibration update:
1. Turn OFF the ignition.
2. Remove the battery positive voltage circuit fuse of the HVAC Control Module (fuse #27). This is located on the passenger side under the glove compartment. Pull back the carpet, remove the carpeted panel to expose the fuse panel.
3. Wait 60 seconds. (Be sure and leave the fuse out for the full 60 seconds.)
4. Install the fuse.
Good luck
Old Nov 28, 2015 | 12:42 AM
BigGun's Avatar
BigGun
http://www.stengel.net/diccodes.htm
Old Nov 29, 2015 | 05:57 PM
SS2001SS's Avatar
SS2001SS
$600??? Ouch!
To Dual climate control
