They have a long history making performance parts, but used to be primarily Mopar. I see the name in more and more performance builds. Used to be really good stuff but not sure about how they are now.
Hamburger name has been around for a very long time, both as a racer and aftermarket (hi-po oil pans I think) parts. IIRC, it was Ed Hamburger that started/founded SLP. Not sure if there is any family connections here though. If I were to guess, I would say there probably is.
Sounds good. Any comment on the ebay special timing cover? I've seen the seller Camarohawk mentioned before with the "cheaper" clutch master cylinder. I'd be willing t pay $200ish for a 2 piece timing cover but not $400+
Yes, It's the same fellow, but I don't for sure if SLP was split off as a separate entity....
