Downstream O2 sensor--which side?
Old Dec 5, 2015 | 01:23 PM
huesmann's Avatar
huesmann
Default Downstream O2 sensor--which side?
Replacing downstream oxygen sensors. Like an idiot I forgot to note which side plug the sensors went. Does the passenger side sensor get plugged into the passenger side socket up by the manifold, or into the drivers side socket up there? The wires are so long they could go either way.
Old Dec 5, 2015 | 05:04 PM
grantv's Avatar
grantv
Sensors immediately after manifolds are same side, downstream sensors after cats cross over.
Old Dec 5, 2015 | 05:56 PM
huesmann's Avatar
huesmann
Thanks. I figured that out after I tried to plug the downstream one same side--they reached, but it was kinda tight, so I figured that wasn't right. I suppose it doesn't really matter either way, except for code ID purposes.
To Downstream O2 sensor--which side?
