Dual climate control operation
Old Dec 8, 2015 | 03:16 PM
Dave Witman's Avatar
Dave Witman
Default Dual climate control operation
97 vette Duel climate control. When I select auto the a/c comes on and stays on even with oat at 50 degrees and temperture set at 90. I have to shut the a/c off manualy. Is this normal
Old Dec 8, 2015 | 06:18 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
Have you looked in the owners manual??? I don't have mine handy, but seams mine (ac)
comes on, and when I turn off ac it blinks, senses moisture in the car!!...after awhile I can turn it off..The ac can be on, with the temp on high,,should produce warm air.. hope this is right..
mike v
Old Dec 8, 2015 | 06:28 PM
mike venth's Avatar
mike venth
mike v
go here -https://www.corvetteforum.com/forums/c5-tech/3175853-window-defogger.html
and read bill curlee's post #7
mike v
Old Dec 8, 2015 | 11:49 PM
johnson-rod's Avatar
johnson-rod
The AC has a mind of it's own. If you second guess it you'll just **** it off and waste your time.
Best way to coexist is to set the temp you want (which had better be 73 degrees) and leave it alone. It knows better.
To Dual climate control operation
