HVAC Problems
Old Aug 28, 2002 | 04:08 PM
ROBROBS's Avatar
ROBROBS
Cruising
Default HVAC Problems
I have a HVAC problem that is difficult to explain. It all started when the AC would not come on; the LED would light for about 3 sec, then go back off again. Just when I was about to take it in to the dealer (hate to; no warranty), I decided to check the DTCs. I found the following error codes on the DTC for the HVAC (99):
U1064 - Loss of communication with PCM
U1096 - Loss of communication with DCM
U1106 - ????
U1255 - Serial Data Line malfunction
So, I decided to clear the codes and try the AC. It worked!! Joyfully, I drove around town for an hour or so, and stopped for gas. When I cranked the car back up and went for the AC, it was busted again! Then and there I decided to clear the codes again. This time, the message I got for HVAC (99) was "No Comm." I tried a couple of more times, but still the same "No Comm" message. The next day I went out to the garage, checked the DTCs again, but this time I got the same codes as listed above! After a couple of experiments, here is my theory. There is something that is heating up, causing the HVAC to lose communication with the main system. I determined this be letting the car sit in the hot sun without cranking it, and I get the "No Comm" error message. Only when the car is cool and sitting in the garage do I get communication with the HVAC and codes that I can clear.
So, gurus of the C5 underworld, any thoughts? Anything I could check/replace that would save me a few hundred $$ ?
Many thanks in advance,
robrobs
Old Aug 28, 2002 | 05:26 PM
YO-EL's Avatar
YO-EL
Default Re: HVAC Problems (ROBROBS)
Control head is shorted... New control head is the fix.
Old Aug 28, 2002 | 05:40 PM
ROBROBS's Avatar
ROBROBS
Cruising
Default Re: HVAC Problems (indypace78)
Thanks. Is this a DIY job or can I replace it (I'm pretty competent with good instructions)? Since I don't have a service manual as of yet, are there any instructions out there on how to replace it? Any idea on the price of this puppy?
robrobs
Old Aug 28, 2002 | 05:49 PM
kenrobb's Avatar
kenrobb
It is not hard, just have to remove the center console piece. Few screws. Try http://www.gmpartsdirect.com for cheapest price. Our 99 had 3 units put in under warrentry. I can copy pages from manual, scan and e-mail if you run into trouble.
Old Aug 29, 2002 | 01:15 AM
redriverjohn's Avatar
redriverjohn
Default Re: HVAC Problems (kenrobb)
If you want the best price for the part, e-mail greg472@bellsouth.net
Greg is a forum member and works for a Chev dealership. He got me a temperature actuator/motor for my dual zone a/c for $15.00 less than GMPartsDirect and his price included shipping via UPS to my door (their price did not include shipping). I also purchased a headlight motor from him and saved major bucks. All parts were new in the box GM or AC Delco.
[Modified by redriverjohn, 11:15 PM 8/28/2002]
Old Aug 29, 2002 | 01:33 AM
Quick Brick's Avatar
Quick Brick
Default Re: HVAC Problems (redriverjohn)
Think I paid 200 for the last one. Just follow shifter swap directions for trim bezel removal. if you have a manual trans that is... Just plug and swap very straight forward.
Old Aug 29, 2002 | 08:26 PM
johnny v's Avatar
johnny v
Default Re: HVAC Problems (Quick Brick)
Would a loss of communication with the HVAC module cause a loss of communication with the TCS module?
To HVAC Problems
