Upgrade to C6 shifter
Old Dec 15, 2015 | 12:24 PM
2ns2ls's Avatar
2ns2ls
Default Upgrade to C6 shifter
Completed the C6 shifter upgrade on my 1998 C5 this weekend (purchased from Cultrag Performance). I'm very happy with the result - it looks nice and still looks like a stock design, is an improved shifting experience, and I re-used the existing boot.
Modifying the boot was very simple, cut a few threads at the neck, inverted the boot over the installed ****, and used a tie strap to secure the top of the boot to the bottom of the ****.
Old Dec 15, 2015 | 07:41 PM
Last C5's Avatar
Last C5
Nice job. You won't miss the old devil key on the C5 shifter if you ever have to do any work on the car.
Old Dec 15, 2015 | 08:07 PM
jackthelad's Avatar
jackthelad
I really did not like the fact that the C6 shifter moved the gear shift **** toward the rear. I installed one - then removed it, the **** was just too far back. Currently running a cut down C5 shifter with a new **** - and liking it. But, I really like the look of the C6 shift ****.
Old Dec 15, 2015 | 10:05 PM
grantv's Avatar
grantv
Completely with you except for the C6 ****. I find the side tilt on the pattern really off putting. Otherwise I do like it.
As for the rearward bend, I could not use one because of it. The way I'm positioned the **** being further back would just not work.
I sawed off about an inch on the C5Z shifter shaft IIRC, then got a **** from TwistedShifterz. Happy.
Old Dec 15, 2015 | 10:32 PM
bartsky's Avatar
bartsky
Is that homelink on the side there??
Old Dec 16, 2015 | 01:25 PM
2ns2ls's Avatar
2ns2ls
Yes - I purchased a used visor HomeLink module off eBay for $20, and then installed it behind the center console with the buttons exposed through the carpet. Works great - very easy to reach.
To Upgrade to C6 shifter
