Fixed leaking tranny tonight...
Old Aug 29, 2002 | 12:38 AM
Phil97SVT's Avatar
Phil97SVT
Default Fixed leaking tranny tonight...
Tonight I decided to fix the tranny while I waited for the differential to get back from the shop. Fixing a leaking tranny is very easy. The case is held together by roughly 8 or 10 bolts after taking the bolts out the rear end of the case will come off with the blow of a rubber mallett. The surfaces are not perfectly flat so I took some carb and brake cleaner and cleaned the surfaces very well. I added some sealant, let it tack up for 15 minutes and torqued the bolts down to 37lbs. After waiting 2 hours I added fluids and no sign of leaking. :yesnod: So far everything is finished just need the differential and we'll be set for the corvette meet @ Capitol Raceway in Maryland.
Phillip
Old Aug 29, 2002 | 02:10 AM
Viprklr's Avatar
Viprklr
Default Re: Fixed leaking tranny tonight... (Phil97SVT)
:cheers:
