headlight problem
Old Dec 23, 2015 | 01:34 PM
J. R.'s Avatar
J. R.
Default headlight problem
when my headlights go down....immediately after... the right headlight makes a ticking sound for about 10 seconds...... can someone please help me solve the problem?
Old Dec 23, 2015 | 02:19 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Sounds like the plastic gear has given up. Several supporting vendors have a brass replacement that isn't too bad to install.
Old Dec 23, 2015 | 02:49 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
You need to replace the gear and while your at it, do the other side. I will need it soon.
Old Dec 23, 2015 | 03:13 PM
frsr06's Avatar
frsr06
http://rodneydickman.com/corvette.html
Google C5 headlight gear youtube and there are several clips for DIY.
While you are in there I would also change out the little rubber bumpers - there are 4 on each headlight.
Old Dec 23, 2015 | 08:23 PM
J. R.'s Avatar
J. R.
google c5 headlight gear youtube and there are several clips for diy.
While you are in there i would also change out the little rubber bumpers - there are 4 on each headlight.
thanks to all for your help!
Old Dec 23, 2015 | 09:08 PM
GCG's Avatar
GCG
It seems you probably have a broken plastic gear in the headlights.
Get a kit like this one (pay attention because there are 2 different kits: one for "97 to early 2000" and another for "late 2000 to 2004") and follow these step-by-step directions. You'll save money and they will last forever
You might need these as well (the rubber bump stops).
There is a TSB, that calls for shimming the driver's side motor. The parts needed for this are included in the above mentioned kit.
Old Dec 23, 2015 | 09:12 PM
BIGGDADDYWIGGS's Avatar
BIGGDADDYWIGGS
Banned Scam/Spammer
Default Getting ready to install Non popup headlights this week
Hello, James from Augusta here, im installing non popup headlights this week, wont be needing the old ones. already repaired both motors with Brass Gears and the Metal T-Brace across the bolts on the Motors for Support. My car is red but you can use the motors. i can probably let one go fr $50.00 just to get rid of them. call me on my cell at 7068334390, James.
To headlight problem
