Does anyone know what the thread pitch is for the 18mm rear upper control arm bolt is? I need to get a tap to clean up the threads in the control arm mount/nut. Thanks!
Are you speaking of #9? If so, that is not a "18mm" bolt. It's a 12mm x 1.75
Oh, I see. Got it. Thanks guys!
Tip for future reference: When looking for fasteners, whether it's bolts OR nuts, etc, never reference the wrench size as that can vary all over the place, especially when dealing with factory OE fasteners. That applies to both metric and SAE fasteners.
General rule of thumb: When it comes to bolts, wrench size is generally 1.5x the thread diamater. Of course, it's not an exact measurement. For example, a 1/2" bolt will have a 3/4" head, same for 12mm bolt with an 18mm head. Now, when you start dealing with nuts that are heat-treated, that rule goes away.
1/4" bolt- 1/2" wrench
5/16 - 9/16 wrench
3/8- 5/8 wrench
1/2- 3/4 wrench
So on and so forth
$.02
P.S. A thread gauge with standard and metric pitches is a very useful thing to have.
5/16 - 9/16 wrench
3/8- 5/8 wrench
1/2- 3/4 wrench
So on and so forth
$.02
On the U.S. side of things, the standard formula of many common "bolt-to-wrench" sizes is to add 3/16". IOW, add 3/16" to the bolt size to get the wrench size.
This is true for several of the common/popular sizes, but not all, as when you get into the larger bolts, it changes. For 3/16", 1/4", 5/16", 3/8" and 7/16" though it does apply.
