Help with Guage needles...just installed white faced gauges
Just put in white faced gauges and apparently bought the cheap kit ($38). I had to remove the needles to put it on...when putting them back on, I'm not sure how to reconfigure them. I've got them where they all look right at startup (8-9 o'clock), and they all return there if moved higher, like normal. However, they don't go all the way up (ie, only to 5k rpm, 160mph, etc)...
What do I need to do to configure these properly...?
Thanks,
Josh
Thanks,
Josh
Re: Help with Guage needles...just installed white faced gauges (TopDog)
That's the easy part...do a search and you'll find one (search white face). I think Vetteessentials also has instructions for their trim ring (very good instructions)...
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
Re: Help with Guage needles...just installed white faced gauges (PaceThis)
PaceThis,
The C5/Z06 guage cluster needles are NOT supposed to be removed. The C5's cluster gets thrown off badly anytime the needles are removed and this should be avoided at all costs.
We have heard a lot of permanent damage occuring when the needles are removed from the Corvette clusters.
Shawn
Shawn
Re: Help with Guage needles...just installed white faced gauges (L.A.P.D.)
which "cheap" white face gauges did you buy?
If you bought the indiglo gauges (they can be changed from green to blue), the needles do not need to be removed! :eek:
Re: Help with Guage needles...just installed white faced gauges (RPOZ4Z)
it was the indiglo set, but the directions specifically called to remove them...and they didn't have the spacing cutout required to go on without the needles removed...has no one figured how to recalibrate if they came off?
I don't think anybody has been brave enough (up until now) to buy the ones you bought! :D
I paid $45.00 for the ones with the Z06 type lettering.
only to sell them with my old cluster when I upgraded to HUD.
If ya dont mind me asking where can you get the guages with the z06 styling? I have been looking for them!:)
Cruise-In IV Veteran
Re: Help with Guage needles...just installed white faced gauges (99NassauVette)
Uh Ohh! :nonod: You are going to have a time trying to get them back to normal.
Even though it says to remove the needles you do not have to. Trust me, they will go on. It looks like they will not but you have to tuck the plastic under the gauge needle and then slip them on. IM or email me for my phone # and I will walk you through it.
Re: Help with Guage needles...just installed white faced gauges (C5-VERT)
I've got the gauge faces on...you don't happen to know how to recalibrate the needles do you?
Josh,
I might be able to swing an extra cluster face with virgin needles w/out the electronics, if you don't get this figured out and you can start over :)
Kyle
Kyle
Pacethis,
I have done a gauge face change on my Miata that required taking the needles off. The first thing to do it warm the car up to the proper temps and take a photo of the needles in their original position... Of course hindsight is 20/20 right ;)
Anyhow, what you will need to do, is leave the cluster open and start your car. Let it warm up to operating temp and either use another vette as reference or use your memory (I know my fades time to time). And then very LIGHTLY press the needles on in the correct position. You don't have to put them all the way on until you turn the car off... The hardest part of course will be the speedo... You could either use the cruise control as reference or have another vette pace you. Have a co-pilot press the needle on for you... It may take a few tries to get that one perfect. Filling your gas tank full will help getting that needle set where you want it as well. Hope this helps.
-vanroth
PS. If you need some help, I'm right by in Greensboro.
-vanroth
1 Post
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Re: Help with Guage needles...just installed white faced gauges (vanroth)
DOH!! :eek: :eek: :eek: :eek:
Hope it works out! :cheers:
ebay :yesnod:
Pacethis,
-vanroth
-vanroth
