Impact to remove head bolts?
Old Jan 8, 2016 | 12:30 PM
ericdwong's Avatar
ericdwong
Default Impact to remove head bolts?
About to pull my heads, started with the passenger side. The 15 mm bolts wow, those were stuck I so far did it with a breaker bar with cheater, but some of them require a really odd position almost me climbing onto the windshield. Wondering if it's acceptable to impact off these bolts. I'd start at the lowest setting and progressively move higher. Saw a thread on LS1Tech about this but the opinions were mixed. Don't want to run into potential damage like the cradle nuts but dang using an impact would save lots of time and swearing. I'll be installing the ARP studs and yes, those will be installed completely by hand, with a torque wrench, in the correct sequence
Old Jan 8, 2016 | 12:34 PM
Johnny wangwang's Avatar
Johnny wangwang
The cradle nuts cant have an impact used on them because you will break the Rivets that hold them in place. The head bolts have no rivets. But what they do have is a tendency to break every once in a blue moon. So I wouldn't use the impact to break them loose. Break them loose by hand and then take them out with the impact if you want. But Head bolts would be one place I wouldn't use air unless I had to.
Old Jan 8, 2016 | 12:37 PM
tommypenguin's Avatar
tommypenguin
I used a breaker bar to remove my head bolts and was pouring sweat after removing them. Looking back there is no retainers or anything like is the case the with the front cradle bolts that could be damaged. I think you are good to go with air tools if you break them loose using breaker bar.
Found this thread...
http://ls1tech.com/forums/generation...air-tools.html
Old Jan 8, 2016 | 12:46 PM
zachaeous's Avatar
zachaeous
When I rebuilt my LS1 I used a breaker bar and did it by hand. I came to the decision from talking with the techs at the local Chevrolet dealer. They said due to the aluminum block and the possibility of thread damage with the impact they broke them lose by hand and then used a impact turned down to low power to remove them.
Old Jan 8, 2016 | 01:32 PM
StingrayRebel's Avatar
StingrayRebel
breaker bar to break them loose and a cordless impact the rest of the way works pretty good... I would never use an impact to initially break them loose
Old Jan 8, 2016 | 04:40 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
here is a good rule of thumb. Never use air unless you absolutely have to. Nothing good ever comes of it.
Old Jan 8, 2016 | 06:59 PM
Hard to argue with that. You sure don't want to shear off a bolt in the heads or the block.
Old Jan 8, 2016 | 07:17 PM
Cheesecake 07's Avatar
Cheesecake 07
Nope. Use a breaker bar to break em loose and finish em off with a cordless like suggested above.
Old Jan 9, 2016 | 07:02 PM
jakecol's Avatar
jakecol
From what I understand, when removing a machine screw which is somewhat harder than the material it is being removed from, bad things can/will happen.
Old Jan 9, 2016 | 09:40 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Use a jack handle on the breaker bar, and eat your Wheaties. I've broken an ARP stud down in my block before. You don't want to live through that hell.
To Impact to remove head bolts?
