Do I have and external fuel filter on 2003
Old Jan 8, 2016 | 02:19 PM
skyscraperac7's Avatar
skyscraperac7
Default Do I have and external fuel filter on 2003
I understand they dropped external fuel filter in middle of 2003 ???
If so at what vin did this happen?
Old Jan 8, 2016 | 02:35 PM
StingrayRebel's Avatar
StingrayRebel
not sure on the vin but you can look behind the driver side rear wheel, it will be on the inside of the frame rail if you do have one... and if your fuel pump is in the bottom of the tank on the drivers side then you should also have an external filter
Old Jan 8, 2016 | 07:08 PM
LoneStarFRC's Avatar
LoneStarFRC
Default FFS fuel system changeover for 2003 MODEL YEAR
IIRC, the production change was made somewhere in the Oct-Nov ('02) time frame.
Old Jan 8, 2016 | 07:12 PM
I believe if you have an RPO code of FFS on the sticker on the glove box door, you have the filter in the tank rather than exposed on the side of the frame rail. My '03 has a VIN ending in 18960 and it has it in the tank (car built in January 2003).
Old Jan 9, 2016 | 08:58 AM
skyscraperac7
Thanks,the car is some distance away in storage and I am trying to get supplies ready for a spring tune up.
To Do I have and external fuel filter on 2003
