Alternator/starter rebuild as preventative maintenance?
I currently have the heads and the exh manifolds off (headers are Swaintech now). I can EASILY get to the starter now - I plan on cleaning up the electrical connections anyway, as I do drive the car in the rain and snow.My car has 206K miles and is pushing 18 years old. It has the original alternator and starter. Neither have given me any trouble, but I'm wondering if I should get them rebuilt as preventative maintenance since the car is taken apart already. And, without these crucial items the car could literally be stranded
. I also know how much of a PITA the starter is to access when LT headers are in place. This goes against my usual mantra of "if it ain't broke, don't fix it".
Or perhaps there's a way to check how much life is left- like the alternator brushes by taking it to a local alternator rebuild shop? Thoughts?
(yes, I'm aware of the implications in keeping the Valeo built alternator
Quality-Built 6492SN Supreme Domestic Starter - New on Amazon 90.00 put 8000 miles on this summer no issues with the starter !!!
Guess I'll be replacing the starter too
At the rate I'm going I might as well replace the whole car
It started out as replacement of:
AC compressor
Steering Rack & Outer Tie Rods
Harmonic Balancer
Turned into: "While I'm there there.. might as well replace/upgrade" OR finding more broken stuff:
PCM and harness packs
243 Heads AI port and polished + Gaskets + ARP studs + valve covers and coil bracket
Cam
LS6 Intake manifold
LT Headers + studs + Swaintech coating and X pipe + new O2 sensors
Valley Cover (PCV conversion)
Oil Pump
Lifters + Buckets +
Rockers + Trunnion upgrade
Valve Spring kit
3/8" push rods
Timing Chain + Timing Cover (2 piece) + sprockets
Oil pump
Power Steering Pump + LS2 pulley + newer bracket
All belts, pulleys and tensioners
POR15 + top coat rusty frame areas
New Motor mounts
New Parts Washer
Left out the nitty gritty and I'm sure there's more I forgot to list
Now Starter and possibly Alternator
The time and $ going into this has EXPONENTIALLY increased
I replace my regulator asssby.
It has a GM #10353441 alternator and Valeo #2542499 regulator.
I got a replacement on fleabay for $32.50. It is external and mounts on the rear, no need to open up the case.
Here is what I got, listed as a M520:
TRANSPO
M520 1
VOLT REG VL
MADE IN CHINA BY TRANSPO
6 09843 94032 2
WAIglobal a USA company
www.waiglobal.com
It's been working great for about 3 month and 2K miles.
Larry
I replaced my regulator assembly.
I got a [02-04 C5] replacement on fleabay for $32.50...It's been working great for about 3 month and 2K miles...
1) 97-01 Valeo Regulator 2542521B (M530) $32.99
2) 02-04 Valeo Regulator 2542499 (M520) $32.00
Safer than replacing the whole alternator and finding incompatibilities later on, and definitely cheaper!
Has anybody tried just to replace the worn out brushes in the old regulators?
locate replacements.
Here are a couple of pic and the catalog info.
One pic shows a blue cover over the brushes. It is a shipping
cover for protection. On my original regulator, it had a similar
cover with holes for the brushes to go through. To remove
the regulator, unbolt it and GENTLY work the brushes over the
slip rings. Don't try to remove the cover with the regulator in
place (I did
)Larry
A little more info. The brushes were worn out on my alternator and
caused a couple of VERY high voltage spikes. Don't know if this a common occurrence for bad brushes. These spikes were in excess of 17 volts by the gauge and caused the Inst Cluster to shut down and
blew most of the bulbs in my HVAC Display. These only happened about 3 times in the last week before replacement. I had also been getting Charging System Fault occasionally on start up for about 2 months, but the gauge showed the system was charging.
Larry
The high current output goes through the stator and rectifier,
not the regulator
Larry
