Need help locating c clip off intake
Old Jan 17, 2016 | 01:55 AM
seand03's Avatar
seand03
Default Need help locating c clip off intake
I broke one of the gray c clips that hold one of the hoses on the driver side intake. The hose is on the front of the manifold. It's still a c but the tabs on the outside are broken. Is that something I should replace or just put it back in and dab on some silicone?
Any idea on a part number or replacement source?
Old Jan 17, 2016 | 07:21 AM
dadaroo's Avatar
dadaroo
Hose for what?
Mr. Sam
Old Jan 17, 2016 | 07:32 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
If your talking about the coolant lines going to the throttle body//
http://my.prostreetonline.com/2014/0...oolant-bypass/
it really won't give more HP
Old Jan 17, 2016 | 12:06 PM
Bigdad's Avatar
Bigdad
Sounds like it is the evap line going to the intake. I hope the picture is there in the link.
Remove the broken lock and replace with a small zip tie.
Bigdad
Old Jan 17, 2016 | 12:26 PM
zachaeous's Avatar
zachaeous
Is this the hose with the c-clips? If it is GM part #12573362 and I do not think the clips are available separate. Mine was broke and I just put them back on till I could get the hose. It was less the $20.00.
Be sure and have your dealer check the Part number for fitment to your car.
Good luck with your repair
Old Jan 17, 2016 | 03:42 PM
seand03's Avatar
seand03
Thanks guys! I wasn't even sure what it was called. Yes it's what is pictured. I'll just use a little zip tie, easier to remove than silicone.
No wonder I broke it i didn't know you just press down I though you had to pry the tabs then pill the clip out oops.
Old Jan 17, 2016 | 10:09 PM
Bigdad's Avatar
Bigdad
Been there done that.
Bigdad
Old Jan 18, 2016 | 09:33 AM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
I used a small zip tie to hold it on. Worked fine.
Old Jan 19, 2016 | 08:32 AM
huesmann's Avatar
huesmann
LOL I see I'm not the first dude to break that little serpentine tube!
I just replaced it with some rubber hose with some hose clamps on the ends.
Old Jan 19, 2016 | 09:02 AM
wcsinx's Avatar
wcsinx
Just replace the whole damned thing with some high-temp silicon tubing. That thing is such a chintzy P.O.S.
To Need help locating c clip off intake
