Should I gut the pre-cats?
Old Aug 30, 2002 | 04:52 PM
rrobert22's Avatar
rrobert22
Default Should I gut the pre-cats?
I am going to get a new exhaust (Z06), and just want a little meaner sound. Nothing too loud, or raspy. I have researched, and some mentioned resonance? I do not want to remove the main cats, for smell, emissions, low end torque reasons. Will I gain any Hp? Will this sound good with the Z06 exhaust? I want a throaty mean sound. Thanks in advance. :cheers:
Old Aug 30, 2002 | 05:26 PM
GaryZ06's Avatar
GaryZ06
Default Re: Should I gut the pre-cats? (rrobert22)
I cut mine out and welded a straight pipe in its place.I read somewhere that GM said it was worth 5 hp.My sound did get a little throatier.
[Modified by GaryZ06, 4:27 PM 8/30/2002]
Old Aug 30, 2002 | 05:47 PM
vettman10's Avatar
vettman10
Cruise-In II Veteran
Default Re: Should I gut the pre-cats? (GaryZ06)
I gutted mine a month or so ago - I believe this is the best bang for the buck mod for a '01 or '02. I did notice more power in the upper RPM range (>4500) and the exhaust note is more throaty.
Old Aug 30, 2002 | 06:18 PM
rrobert22's Avatar
rrobert22
Will I need O2 sims for just the pre-cats? :cheers:
Old Aug 30, 2002 | 06:26 PM
GaryZ06's Avatar
GaryZ06
No
Old Aug 30, 2002 | 06:33 PM
GaryZ06's Avatar
GaryZ06
Here is my car with the pre-cats out with the pipe welded in place.
Old Aug 30, 2002 | 06:47 PM
rrobert22's Avatar
rrobert22
Thanks Gary.
:cheers:
Old Aug 30, 2002 | 06:51 PM
Mike Mercury's Avatar
Mike Mercury
Gary, I wanted to do the same as you did; but feared our states AlGore smog check ****'s catching it during the visual check.
I have done just that; Z06 titanuims with gutted precats. It sounds a lot meaner from outside the car; but is still bearable on the inside.
Like someone said earlier; its a free mod!
my how-to on this procedure:
mikemercury.home.att.net/precats.htm
Old Aug 30, 2002 | 07:54 PM
Conquer's Avatar
Conquer
St. Jude Contributor
Default Re: Should I gut the pre-cats? (Mike Mercury)
THANKS FOR THE INFO MIKE!!!!
Old Aug 30, 2002 | 09:29 PM
rrobert22's Avatar
rrobert22
Too late to go back now, its done :smash: It does sound a little deeper, not much though. Ill have to wait and see what the Z06 sounds like. :cheers:
Old Aug 31, 2002 | 05:53 PM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
Did this make your car start running richer or leaner, also where did you get those exhaust pipes?
Old Aug 31, 2002 | 06:02 PM
rrobert22's Avatar
rrobert22
Default Re: Should I gut the pre-cats? (DCBStingray)
Not sure about the richer/leaner thing. I just left the stock pipes in place and cleaned them out. :D It is a little louder, and meaner, Ill post when I get the Z06ers on there.
To Should I gut the pre-cats?
