Tach output wire for window switch install
Old Jan 21, 2016 | 09:12 PM
rttmike's Avatar
rttmike
Default Tach output wire for window switch install
Can anybody help me out here? I have done a Google search as well as searching here but I'm o. CF mobile and the results are not that great.
Trying to install NOS brand window switch.
Old Jan 22, 2016 | 05:55 AM
dadaroo's Avatar
dadaroo
Can you please provide a better description of what you are wanting to do?
Mr. Sam
Old Jan 22, 2016 | 06:29 AM
rttmike's Avatar
rttmike
I need to find an RPM/tach output wire to signal my window switch for nitrous.
Old Jan 22, 2016 | 06:43 AM
dadaroo's Avatar
dadaroo
Got it. What year are you?
Mr. Sam
Old Jan 22, 2016 | 06:44 AM
rttmike's Avatar
rttmike
Old Jan 22, 2016 | 06:54 AM
dadaroo's Avatar
dadaroo
OK, it starts at the PCM from Pin 10 (White wire) on the Red connector.
https://www.dropbox.com/s/s1qllv99u2...Views.pdf?dl=0
It travels from there to the engine fuse box and then into the car to the IPC.
Where do you want to pick it up?
Mr. Sam
Old Jan 22, 2016 | 06:57 AM
rttmike's Avatar
rttmike
I'm open. Wherever its easier to grab the wire.
Old Jan 22, 2016 | 07:03 AM
dadaroo's Avatar
dadaroo
Probably at the PCM. Finding it in the harness running inside the car would be harder in my opinion.
Mr. Sam
Old Jan 22, 2016 | 07:11 AM
rttmike's Avatar
rttmike
Doesn't the wheel and inner fender have to come off to access that?
Old Jan 22, 2016 | 07:31 AM
dadaroo's Avatar
dadaroo
Yes, but that is easier than trying to fish out the wire from inside the car. You might try to find it inside if you trace the Middle Fuse Box connector C2 harness to inside the car. However there are 3 wires that are White in that harness.
I'll try and help you anyway I can.
Mr. Sam
Old Jan 22, 2016 | 08:53 AM
feeder82's Avatar
feeder82
https://www.corvetteforum.com/forums...-big-pics.html
Here's a good link
Old Jan 22, 2016 | 01:26 PM
rttmike's Avatar
rttmike
I was reading this one as well. I am just not understanding how to test for the correct wire.
Does anybody know if there is a wire that can be used by the coils?
[/I]
Originally Posted by feeder82
Old Jan 22, 2016 | 08:43 PM
feeder82's Avatar
feeder82
[/I]
Read post #20 in the thread I linked to
To Tach output wire for window switch install
