FLP Headers Installation Question
Old Aug 30, 2002 | 11:05 PM
7LitreC5's Avatar
7LitreC5
Default FLP Headers Installation Question
I started my FLP header installation today. I got everything apart, got the passenger side header on, and then ran out of time.
When I get back at it I am going to put the driver's side header on. The instructions say that it can be installed from the top or the bottom. Which is easier? I already have the valve cover off, alternator off, and the steering bolt out with the shaft moved over up against the frame. I am doing the install with the front on ramps and the back on jack stands. The car is a MN6 car if it matters.
I am doing this by myself and the installation really is not as difficult as I thought it would be.
One other question. Should the header to head bolts be torqued to the same spec as the stock manifolds?
Thanks.
Old Aug 30, 2002 | 11:19 PM
Bill Reid's Avatar
Bill Reid
Default Re: FLP Headers Installation Question (mforbes)
Drop the oil filter and stab it from the top :)
(edit) at home now... don't have FLP instructions in front of me for torque specs. Stock torque specs would be the safe bet from the chair I'm sitting in :)
:cheers:
[Modified by billreid1@***.net, 9:21 PM 8/30/2002]
Old Aug 31, 2002 | 12:23 AM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
I did the drivers side from the bottom :) :)
Here is some pics of my install Click Here
Good Luck :) :)
[Modified by Black_Magic, 10:23 PM 8/30/2002]
Old Aug 31, 2002 | 08:13 PM
7LitreC5's Avatar
7LitreC5
Thanks for the info and the link to the pictures!
Old Aug 31, 2002 | 11:38 PM
kh24's Avatar
kh24
I got mine in from the top. I tried the bottom but couldnt get it. I did not have to take off the alternator or the oil filter though. I unbolted the steering shaft and then twisted the header in. One tap of the hammer and it dropped into place. FLP told me on the phone to just make the bolts tight by hand(no air tools)and not to worry too much about the spec which is 18 ft. lbs. if you where wondering.
Old Sep 2, 2002 | 10:30 PM
7LitreC5's Avatar
7LitreC5
When I went back at it today, the drivers header mostly just fell into place from the top once I removed the oil filter. I found when I went to bolt the header up to the head, the header flange was warped outward. When I tightened the bolts it drew it up to the head and it looks ok. It better not leak!
I should finish it up tomorrow. I would have been done this evening but the header kit did not provide bolts/nuts to bolt the x-pipe to the cat-back. The flange on my stock intermediate pipe is threaded and therefore does not use nuts.
Old Sep 2, 2002 | 10:45 PM
kp's Avatar
kp
Use the nuts from the stock exhaust manifold studs and the stock bolts from the exhaust flange..
To FLP Headers Installation Question
